injectors wont fire??
Started by 72 Bogger, March 19, 2012, 02:29:16 AM
check the ground wires going to the computer, I believe that they should be grounded on the tranny bell housing, where the trans dipstick is bolted on.  also check all the fuse links, and where they connect up on the firewall, see if there corroded or blown I know from experience if just one of them burns then you ca get the same problem you got.
