Bulldozer
Started by old school truck dude, March 20, 2012, 03:08:05 PM
A bulldozer is going down the road in a straight line. As you can see, there are many individual track pads that make up the complete tracks. While the dozer is going down the road, the track pads on the top are going 20 miles per hour. HOW FAST ARE THE PADS ON THE BOTTOM GOING? Post your answers! ;D
pads that touch the ground dont move :)
72 Bogger
id say 20 mph but i know thats wrong so i dont know.
drive like you stole it
Slick
Pads on bottom are going backwards.  -20mph
Were #1 <---- Click & See!
Mudgrunt
fast enough to keep up with the ones on top
Life is not a dress rehearsal
Newbie
haha i new it was a trick questions so my guess would be 20 miles per hour.. but after seeing slick saying -20 b/c pads are going backwards i change my answer to his :P
The pads on the ground are going 0 relative to the ground. The speed of the top pads is irrelevant.
If the bottom pads are going -20 and the top Pads are going 20, your dozer is stuck
black07ss
Quote from: ProGrade on March 21, 2012, 01:27:10 AM
Haha I'm with prograde on this one!! Lol!  loll loll
The pad stops movin when it hits the ground, and it doesnt start movin again until it comes comes back up off of the ground.   ;D ==rocks ==roxs ==roxx yeahh loll ==roll ==ha woho woho ==what ==rant ==bartmoon ==fa-q ==hi ==beavis ==evillaugh
wayne w
Quote from: old school truck dude on March 21, 2012, 11:34:37 AM
x2
HockeyGuy
x3
#11
They're going 20 mph, along with the machine. Every bottom pad becomes a top pad in a few seconds. They are moving forward, because each pad has a new location relative to the ground when it contacts it. Just like a tire. Just because the bottom of the tire is touching the ground doesn't mean it's not moving with the rest of the machine.
The pad never stops moving. It travels along the undercarriage of the bulldozer, relative to the machine movement.  It's the illusion of it not moving against the ground that can trick you.
If the bottom pads were traveling at 0 mph then all the other pads connected to it on the top side would be 0 mph as well, a stationary machine. The pads change position on the ground with each rotation, so they are moving.
Question was "How fast are the bottom pads moving?" Not "relative to the ground" or anything like that. If any object changes its place on this earth, 20 miles in one hour, it's moving 20 miles an hour!
It stops movin when it hits the ground and it dont start movin again till it gets picked back up off the ground. Plain and simple, go watch a dozer move around  - the ground aint movin so the pad aint either. The track is constructed of many objects, not just one. Not all of the objects involved in the construction of the track are in constant motion, particularly the pads that are touching the ground. The dozer itself is in motion, but the pads on the ground are not. This is a trick question, theres only one answer ;D
If the pads were moving backwards, they would have loss of traction. Same as a car tire. The contact area of the tire that touches the ground doesnt move. If it did you would have a loss of traction. ;D
big red
People way over though this.
then what the answer!!!  Big red
big red
Newbie
you guys are crazy.   lol
Quote from: old school truck dude on March 30, 2012, 12:05:00 PM
Yeah but 20 miles an hour doesn't imply the motion has to be constant. If the pads on the ground, not moving, end up some place else in 20 miles after one hour, they too have "moved" a total of 20 mph ==roll
