My 1983 k20 4x4
Started by 383stroker, March 27, 2012, 04:11:29 PM
I might have a couple extra blocks up at gramps... check my pile of "junk" out in the other barn. Stacking the blocks isnt a good idea might pop outta there.
crimedog70
kyle wont listen he will prolly leave it a f it all up
bandsaw1996
this truck sucks monkey nutts ==np
aulbert #74
that looks like an aluminum lift/lower block, the lower steel block and the leafspring will grind that thing to pieces. get that out of there! and someone tried to save your wasted front springs with a cheap extended shackle, you should look into a used lift kit that will come with new front springs.
hanksheating
dniels2000
Since I took this project bogger over, We finished a whole new brake system, add 38x14x16.5 tires, cut half the crap off the frame and around the truck that didn't need to be there, moved the battery inside the cab, those wires you had on the motor were way to big, so replaced those, added springs with a 6" lift on the front and still working on it. I will post pics once she's done so you can see what she has become....lol
crimedog70
cool man i cant wait to see it done we had no time and no money lol to do anything with it i wanna see it when its done
crimedog70
crimedog70
dniels2000
Well its been done for a while just haven't had time to get on here. But we pretty much tore it down and recreated it. Its a beast and i have a blast with it.
dniels2000
dniels2000
its came a long way from when i bought it!
yukonjake
Looks like you had a blast boggin her thats all that matters
crimedog70
