208 or 205?
Started by michigan maniac, April 08, 2012, 07:00:34 PM
Quote from: homewrecker john on April 10, 2012, 01:34:13 AM
or have mudbuster make you his special adaptor....then you will be able to run the 208 with out shaft change.....
Thanks was also told I could redrill the stock 203 adapter to make it work
Quote from: michigan maniac on April 10, 2012, 02:19:31 AM
Thats what JOHN was refering to.   There is alittle bit of welding involved.............but its alot easier than tearing into your trans.
curious about what yall r talkin about.....details???
Quote from: Jjay78 on April 11, 2012, 02:44:06 AM
I have a turbo 350 trans that is designed to run either 203 or 205 27 spline transfer case, it is a short style rear output shaft, I have it setup right now to.run the 205 which is gear to gear case, with 1.96:1 low range,  I have a spare 208 aluminum chain drive case with a 2.6:1 low range that I was debating on running, but it requires a long style trans output shaft, in order to make it work with my trans I would have to tear the trans down and change rear output shafts, OR like stated above build a custom adapter that will allow me to use my short style trans output with the 208 case so I don't have to tear the trans apart...  Hope that makes sense lol
The reason I want the 208 is for the lower gear ratio
The 203 adaptor can be modified for the 208 to work on a tranny that was orignally for a 203 with no shaft change.
mudbuster on here makes them pm him. he uses a 203 adaptor and makes a 208 work with it some drilling some welding then your put it in and go, just did it on my truck took the 205 off and swaped a 208 on...
Quote from: michigan maniac on April 09, 2012, 04:15:07 PM
Yeah its not much more weight to add just the front gearbox, I already have everything to do the doubler except the $700 adapter kit lol
i got the 350 to 205 adapter. but i dont know what the tail shaft housing bolt battern is.
Quote from: betterbeaters on April 11, 2012, 06:15:28 PM
Yeah I sent him a pm, just gotta debate on getting it done, I just bought new $80 yoke for the 205, and if I keep.the 205 ill be able to hopefully reuse my current rear drive shaft,
Either way the front has to be made, so its a toss up
Quote from: Jthomas on April 11, 2012, 07:00:56 PM
I've already got the 205 and 203 adapter, thanks though!!
Can't you regear the 205?  Heard that somewhere
Quote from: Blazin40s on April 12, 2012, 06:09:51 PM
yep get a lowmax 3:1
^ there ya go....problem solved....what do those gears run alex?
You can't regear a stock 205, the case won't allow any bigger gears to be Installed, the lowmax setup comes with a new custom case, and gears then gotta swap the rest, can't event find them anymore through jbconversions, and from what.I could tell they are about 2 grand if you can.find them,
you can fit them in a stock case just had to grind everything down inside to clear. and yes they are about $2000+
The 208 is 2.6:1, the lowmax is 3:1, not too much of a difference for over 2 grand.... I think ill save some money and run a 208!!! Lol
Quote from: michigan maniac on April 13, 2012, 02:09:35 PM
lol yep way cheaper and easyer!
Quote from: homewrecker john on April 11, 2012, 11:27:14 AM
how??!!!?????
Quote from: Jjay78 on April 14, 2012, 02:25:07 AM
how??!!!?????
By re-drilling and welding the adapter to fit the 208,
