Temp gage gone bad?
Started by haydenlloyd88, April 14, 2012, 03:56:02 AM
haydenlloyd88
I mentioned that my truck had Alittle over heating issue it a previous post. So I flushed the radiator and put a new thermostat in but it didn't help according to the gage. And today when I was driving the truck after it sat all day, the gage got to 260 degrees after a few minutes of driving 30 mph. So I pulled over and popped the hood but there was no signs of over heating. The radiator cap wasn't even hot. Could my gage be bad?
going through the same thing man, that's my last guess too
haydenlloyd88
Quote from: Jjay78 on April 14, 2012, 03:58:25 AM
I mean that's gotta be it right? A motor can't get to 260 degrees with out making it known right?
at that temp your coolent would let ya know real quick
haydenlloyd88
Quote from: Jjay78 on April 14, 2012, 04:17:17 AM
Exactly, but the radiator cap wasn't even hot, you could
Hold your hand on it no problem
System building pressure in the hoses?
I had a temp gauge problem with a s10 blazer... gauge would jump up 40 degrees whenever I turned on the headlights. ==roll
jbeery78
If the rad cap was cool to the touch then the coolant wasnt even hot enough for the stat to open. Id say bad gauge or bad sender. Make sure all the air is out of thw system. Air pocketa cause hot spots.
MR. Horsepower
we had a guage 2 times that was stuck and ran right up amd pinned the guage
haydenlloyd88
Quote from: jbeery78 on April 14, 2012, 11:15:56 AM
How do I work out air bubbles
Run up to auto zone, grab one of their $20 special temp gauges and hook that up. that will clear it up.
