1995 jeep grand cherokee WONT START HELP!!
Started by farmer, June 03, 2012, 04:55:22 PM
farmer
i have a 95 grand cherokee that wond start, but sometimes it will.the batterie is good same with the starter and it getting power to the coil i tried changing the crank position sensor but didnt help if you have any ideas please help me out thank you
85cHeavyMetalBogger
Make sure you are getting spark.  If you are check fuel pressure if your not getting spark maybe the computer if you already put in a new crank sensor.
mud gremlin
I had a problem on my old 95 and it was the alarm
Go big or go home
farmer
not getting spark... i was told to cut the alarm wire and ground it out but didnt make a differenct has great fuel prssure
85cHeavyMetalBogger
bmwallace_88
yeah if you're getting power to the coil and no further, i'd say the coil is shot.
