DD project
Started by BUDGETBOGGER03, June 14, 2012, 01:32:06 AM
Well i got this jeep about a year ago and decided i would now make a project page for it cuz im bored!
got this off a family member real cheap!
its a 4cyl wrangler with a manual ax-5 and it has 4:11 gears
since i have had it i put some aluminum rims on it that are in the picture below. and a set of smitty built side steps
i had to put a computer in it last summer and the syncros  are going bad in the trans so it grinds!
oh i forgot i cut the cat off and muffler and put on a thrush turbo!
got a little stuck, and a pic with the steps on! ==doh
http://www.quadratec.com/products/16110_008.htm
ordered this yesterday now need to find a set of 31's or 32's
lift shld be on by next weekend!
1 ton tj
do a spring over it will give you around 2 1/2 - 3 inch more lift.
off road the way of life
Quote from: 1 ton tj on June 20, 2012, 06:46:48 PM
X2
Spring over on a Wrangler is closer to 5" of lift.
i font have money for drive shafts or i would maybe in the future
lift is on looking for tires
Maybe I'm wrong but I'm pretty sure a springover wouldn't need driveshafts...
Quote from: burl on June 27, 2012, 10:04:17 PM
it would it adds 3-5" of lift .
Quote from: betterbeaters on June 27, 2012, 11:31:50 PM
x2
It will only grind if you don't know how to float a non-syncronized transmission! ==roll
hoping to get rims and tires in the next month
thinking maybe these rims
http://www.quadratec.com/products/92605_7XX_B_PG.htm
 ;D
yukonjake
We got a kit from texas fabrication off ebay without shocks for 206 it came with very good directions and we go 5.5 inches of lift out of it
Quote from: yukonjake on November 26, 2012, 05:27:11 AM
gotta link?
yukonjake
I dont ill see if i can find it it was a well put together kit though
