Stock sbc head spring lift
Started by 84silverado, June 21, 2012, 06:02:08 PM
84silverado
ive been thinking of taking some of my graduation open house money and either
A. buy some aluminum heads that are plenty enough for my use.
B. buy me some .600 lift spring and know my stuff is safe
C. get out of bogging loll
i highly doubt that C. will EVER happen  ;D
I  would suggest A :)
but if you do decide C   just know I am here to take all the donations you would like to give  loll
if your looking for heads dont forget to look at iron heads.... my darts have bigger #s than most alum heads.. and when buying stuff bigger may not be so better you need everything to work right together..
84silverado
yea i called around about who would redo my cast iron hi-po 327 heads i have but, with everything i want done to them it would take a month and im leaving in a month for bootcamp so i think im gunna get these, they look like a good head for my use... im ordering them later today or tomorrow but they wont get here in time for me to put the on for vernon rd bog  :'(
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350546611958&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
85cHeavyMetalBogger
Quote from: Jjay78 on June 23, 2012, 02:08:58 AM
there's a couple things i've cought off this thread... first, not all sbc heads had the same size runners, if your compareing 461's to 882's  then the 882s are gonna make the 461 look like they've been ported like crazy... second the lift and life span for each set of stock springs varies immensely from head to head depending on what the heads were intended to go in.. aka, stock chevelle heads vs stock truck heads... best thing to do is take the springs off and have em checked for straightness, and fatigue and for coil binding point... if your gonna be reving on it i would highly reccomend droping weight out of your valve train, trying to save money in your valve train can end up costing you more in the long run.... new valve springs... retainers...and some lighter stronger valves might set ya back a lil now, but then you'll know exactly what you got going on in your motor, and everything will be in unquestionably good condition......
well said.
84silverado
Quote from: 85cHeavyMetalBogger on June 25, 2012, 10:39:00 PM
well said.
It was
Boggen Joe
Looks like a good set of heads
also whats the rocker arm ratio?
figure out what the bind height is
84silverado
Heads came in... Felt like christmas opening them up loll
Quote from: 84silverado on June 29, 2012, 04:31:45 AM
looks like a real good set for a decent price, I might have to get these on my next sbc build, after you get your motor all together, let me know how they work out for ya :)
84silverado
These heads are faucking awesome... They are prefect with my cam... I fine tune my carb and time it better and ill be doing great
