1310-1350 conversion joint
Started by Kyle, October 11, 2012, 11:51:23 AM
im tryin to find a conversion joint for my front shaft to pinion. the diveshaft side has to have a groove(1310) and the other can be grooved or plain(1350). not havin a whole lot of luck with the search....
BigWheelBob
Actually the above one's are not correct for what he needs. With the groove in the shaqft side, he would need a GM3R to Spicer conversion joint. Spicer doesnt make this joint, however Naepco does with a part#: of 11-00503R .
Quote from: BigWheelBob on October 13, 2012, 10:19:22 PM
I was told by a driveline "specialist" that those dont exist tho... ???
BigWheelBob
#4
Crap, try this one. 2-1153. The above might be a factory number. Or 3-3140 for a joint with all 4 outside clips. Spicer also makes this joint, it is a 5-460X.
