MY D.D/TRAIL RIG/BOGGER
Started by Merc09, January 29, 2013, 01:40:42 AM
Merc09
How would I find out for sure. I've never heard of a 243 t-case. I've heard of 243 gears tho.
Back of the case will have a small tag. It will say model, and have numbers. Go look to be sure.
Merc09
Merc09
NP241- manual transfercase, shifter is on floor
NP243- electronic transfercase, push button selector on dash,
NP246- electronic transfercase, push button selector on dash w/ autotrac,
If you got a button, not a lever, its a 243. Manual lever is 241.
Merc09
I have the electronic push button on the dash. So I must have read the tag wrong? Thanks for your help.
chevroletj5
be careful hauling 8000 ound vehicals with that 4l60e...make sure you got a BIG trans cooler and good fluid in it!
Merc09
Quote from: chevroletj5 on February 10, 2013, 06:14:08 PM
I've only hauled that much a couple times and it wasn't for a very far distance just a few miles or so. And I always check oil and trans fluid before I haul anything. I can't afford for something to be low and then I end up blowing something up. It's a z71 so it comes with a trans cooler from the factory. But thanks for your advice!
Merc09
Merc09
Just painted the frame/underbody and leafsprings, shakels, control arms, trailer hitch, and inside the wheel wells today. Man it looks good!
It's amazing what underbody paint does isn't it'?
MudDigger
cool lookin truck man i pretty much have the same truck just a little bigger myns a 96 z71 ext cab shortbox 6in bds lift bought it for 800 well i traded a 800$ truck for it anyways lol
Merc09
Quote from: ProGrade on May 19, 2013, 03:24:04 AM
Yeah it is. It looks great.
Quote from: MudDigger on June 22, 2013, 12:33:57 PM
Yeah i want to build it up but not anytime soon. Eventualy i want it sitting on 44's
Red97
Just save your money up until you can afford to right axle the truck. Dont waste any money on a ifs lift. , like I did. I hated my 6'' fabtech  lift. Sold that now im running d60 front 10.25 rear 7'' lift and 35's.Rides better now than ever.
Merc09
Update. ive removed the brush guard temporarily so i can paint it up and make it look nice. someone backed into the side of my truck so the bed is dented in now but my girlfriends dad is going to do all the bodywork to it so im going to fix all the rust. i put a new pitman arm on and new brakes all the way around. i also did both upper ball joints a month ago. im getting new shocks soon and monday ill be putting both inner and both outter tie rod ends on along with new plugs, wires, cap, and rotor. oh and new tortion keys. this thing is going to ride like new again!
Quote from: Red97 on June 22, 2013, 04:26:28 PM
yeah im going to straight axle it when i lift it. id just waste my money with the ifs lift because i want it straight axled anyway.
Merc09
Got some new boots for it!!
Merc09
Close up lol
