Backspace question with Dana 60
Started by GTOKILLER, October 01, 2013, 01:08:53 AM
GTOKILLER
Im looking to buy some Boggers but they need 15" wheels, what offset do I need to clear for sure??  Ive been told 3.5  or 2.5 or 2 but I would rather know for sure what Im looking for, thanks!
NOS is like a hot chick with STD's, you know u wana hit it but your afraid of the consequences!!!!!!
fordrunner
GTOKILLER
fordrunner
My 88 f350 has massive brakes and 2.5 bs clear fine
Quote from: fordrunner on October 01, 2013, 01:47:56 PM
my Chevy had normal brakes and I had to grind.
mudbillyredneck
#6
2" is the prefered backspace ..
example 's :
An older (80-92)ford kingpin front axle has a larger duel piston caliper..and a dated glide pin style brake system.. 2.5 will work.. but it will make contact with the pad tab's ..2" will clear everything... and not touch anywhere
The newer ( 93-97) Ford balljoint 60 front axle , the caliper is a tad bit smaller and bolt's on , alowing a 2.5 to just clear
hope this was usefull info ... although it may not apply to other model year or brand dana 60's ... I can only speak for fords
I stay away from chevy,dodge ,and superduty stuff....so I cannot provide any info on those clearance requirement's
GTOKILLER
Thanks for all the info guys, I hate to admit but its on a dodge Dana 60 pukee but I ended up with is after a few trades just to play with in the mud my son loves big trucks. Im strictly a SuperDuty guy! got 3 right now have had 5-6 over the years. It seems to have kinda small brakes, Ive got access to a 2.5 ill try it out this weekend before I buy anything.
mudbillyredneck
Then there is what Marsh racing wheels calls a " REVERSED " wheel. He flips the wheel around so the outside bell becomes the area over the brakes ...then welds in the center...which works very well , and helps to cheat an 1" or so out of the backspace ...
with a reversed wheel .. you can generally run 2 1/2 instead of 2" .
Some also argue that a reverse wheel has the better bead seat to the outside that way... a redneck beadlock if you will  ;)
fordrunner
Quote from: mudbillyredneck on October 02, 2013, 01:08:16 PM
.   Wow ya I forgot mine were reverse wheels my bad sorry dude guess I just asumed all the wheels with 2.5 back space were reversed all of them I had are
mudbillyredneck
Quote from: fordrunner on October 02, 2013, 02:14:47 PM
Most are ...yes
But there always seam to be a set of ...." HOME DO....Job's " floating around ....LOL
Hope this info is of some help to someone out there on this forum.....duel duty trucks that see street use ...should never grind on there brakes .....in my opinion
