Cummins 2 1/2 ton. "Yahtzee!"
Started by 84blazer, October 18, 2013, 06:54:37 PM
just one more
how much drop do you have from the bottom of your body to the
bottom of sub frame? just trying to figure out where mines going to sit,
lol i think i made it a little bigger than i wanted.
84blazer
Quote from: just one more on April 28, 2014, 05:37:33 PM
I made mine 24 inches, roughly half the heigh of the tires I have. From what I figured out that is a good starting point.  I thought mine was going to be to big to until I got it out of the barn when it was all done. Lol
just one more
ok, mine is 22" and my tires will be 45-46 when mounted, thanks man!
Awsome pics, how did the test and tune go ?
84blazer
Quote from: michigan maniac on April 28, 2014, 09:43:53 PM
It went great, all I have to do is put another vent on the fuel cell, the one in the fuel cap isn't enough, it was sucking the fuel-cell in on itself. And I have to clearance the yolks with a die grinder a little. Oh and I have to get it clean again LOL
just one more
and by the way that truck has a great stance, looks niiiccceee
I.D.
What's the first bog your going to
84blazer
Quote from: I.D. on April 28, 2014, 11:06:36 PM
Country compound will be the first one
84blazer
So luckily I checked the diff fluids. Ended up finding water in the front axle. So tore it all apart last night and figured out it was leaking in on the diamond side of the 3rd member
Damn that sucks, that's a lot of contaminated gear lube, better the tearing the axle up tho
84blazer
Got the water in the front axle problem fixed
justin0421
Where ya gunna take it now that country compound is cancelled
84blazer
Hoping I can make it to Run What Ya Brug this weekend. Then the one in wadhams the weekend of the 18th
mud gremlin
Go big or go home
84blazer
mud gremlin
Go big or go home
justin0421
Clinker
When in doubt throttle out.
