Prograde's Cherokee
Started by ProGrade, December 11, 2013, 07:18:51 AM
WHITE KNIGHT
Sounds like u been busy there , good luck hope to see u soon out there , Sunday was a blast with  the snow , and beautiful out there  ,  a=f
I Got Mud!
Quote from: WHITE KNIGHT on December 16, 2013, 11:01:46 AM
somehow between working 7 10's last week and completing school work, I managed to carve out a 3 hour block of time.  I've mocked some stuff up, but gotta stay busy this week so i can get out there...I'm sure it was awesome out there!
Merc09
Why not just get some rims with some offset? Lol. Better than spacers imo.
Quote from: Merc09 on December 16, 2013, 03:38:51 PM
good point.  Either way it will end up tearing up sheet metal.
WHITE KNIGHT
For me and what iv learned over the years , I stay with a tire in the range of 30 and a stock 7" rim .right now I got 8" and it sucks with the bead  always getting wood stuck in them or mud. Lol we always cAry a old school bumper jack for quick break downs on beads , clean out , air up back to wheeling , pat ran 33s but also went back down to a smaller tire ,really not there to play in mud , just go in to the tight as* trails and climb up and out  , of ? However if there is mud to cross then I have mud kings size 30 they do great also good in snow , just a little rambaling, lol
I Got Mud!
Merc09
Quote from: ProGrade on December 16, 2013, 05:25:27 PM
Sawzall solves clearance issues ;D
Quote from: WHITE KNIGHT on December 16, 2013, 07:21:49 PM
I'm gonna stick with the 33's for now just because it's what I have.  They are on stock rims,  I think they are wrangler rims.  I bought a farm jack too.
Quote from: Merc09 on December 16, 2013, 08:26:09 PM
Grinder is cleaner :)
It only rubs in 1 spot on the frame now.  Hopefully tonight I can wrap up the cutting on the rear.  Then make my bump stops do the rest.  Supposed to get springs and coils from a rubicon tomorrow, that will give me extra length to make up for the moved bump stops.  If the coils don't work out I have a line on some f150 coils and some bronco lift coils
Post some pics once you get everything trimmed up!!
Got some work done today.  Drivers side is all trimmed up and I put some door edge guard on the trimmed fender.  Still need to use a hammer in the rear inner fender and weld it to the outer.
Also on the passenger side I was putting the bump stop spacer in so I tried out the jeep rubicon shock and coils I picked up.  The coil seems the same, but the shocks are longer so I'm not sure what the deal is.  Also got a 33" spare.
Shocks are longer so the rubicon had more suspension movement I would assume
derbydude
Are you going out to mounds Sunday with it ?
Won't be ready by then, I was in a major accident yesterday so I'm laid up for a few days
derbydude
Quote from: ProGrade on December 19, 2013, 09:04:41 PM
sorry to here that , hope you get feeling well soon. anything I can do for you just ask , I do not live far from you.
Quote from: derbydude on December 19, 2013, 10:46:35 PM
thanks, I'm not too bad just really sore
Got the passenger side cut today, except the rocker.  I was able to get the rear inner fender pushed up inside the cut outer quarter.  Then I used a bfh to open up some clearance.  The result:  no rubbing with the 33's on that side.  Now I just need to tack the inner in, Coat it and seal it.  I also noticed the rubicon coils sit lower than stock, but seem flexy.  Probably gonna go back to the stock and get rid of the rubicon suspension.
Did some more trimming work and got a front pull point mounted.  Need to reinforce and the make a winch mount out of it.
Mudduck
Mudduck
==hstrap
newS10
ProGrade, Did not know you had a jeep. looks like a mounds jeep to me i will have to get to my 2001 and run with you all. ==wgm ==kp A new project just one more. ==roll pullhairr ==roxx yeahh
derbydude
Looking good , made this for the front of mine. Had a good time at the mounds yesterday. Daughter climbed part way up the rocks.
