Need help figuring this 99 ford 250 out please
Started by 76 chevy shaker, December 12, 2013, 04:43:13 PM
76 chevy shaker
1999 ford f250 single cab 2wd 5 speed. its my company's crap truck. the truck will not start occasionally the starter will engage and then that's it nothing after it acts like someone flips a switch and it just stops. plus some other weird symptoms. i have tested the battery and check the cables and fuses all are ok.
Here is where the weird symptoms kick in. if i put the key in the ignition turn the key the gauges don't show any power if i turn the key repeatedly the gauges start to come up and then i proceed to start it and all that happens is the starter will engage then i loose it all. here is where it gets weirder, when the key in ignition alarm starts dinging if i turn on the headlights the dinging nothing happens when i turn the keys to start the truck and the head lights never come on.
this is the truck my boss let me drive while i get my truck back on the road and well now the trucks issues are my fault in his eyes so i have to figure this out or im S.O.L.
thanks for any imput guys.
My keyboard diagnostic tool says you have a bad electrical ground.
check ground strap from cab to motor and ground strap from body to battery.
go from there.
RaZiN KaNe
Quote from: Hammerlane on December 12, 2013, 04:58:49 PM
go from there.
ive had it happen on both my f250 and f350 and both times it was the ground!
B.G. Grounds Maintenance
For All Of Your Residential & Commercial Turf Needs
76 chevy shaker
Hammerlane you hit the nail on the head it was the motor to cab ground starts just fine now. Greatly appreciate it guys.
