looking to get more wheel speed?
Started by 73chevytruck, January 23, 2014, 12:36:18 AM
High range is very hard on the tran, get a new torque converter that works beat with you specs give Coan a call and tell them what you have and they will recommend a torque converter
Boggen Joe
Dump the 203 n go 208. There strong
I run th350/208 500hp with cut hawgs 44s, 4:88 gears SBC  and can hit 3rd
Do not run hi lock, bad idea,
Go better gears and run through the gears
mudbillyredneck
#22
X 1,000  on what all the seasoned  guys said ..
light wheels....is huge
And running light weight  aluminum driveshafts is a great way to free up HP...and often overlooked buy many
proper stall for cam ...is like a no brainer
run high range if you want...it's just a trans...you can always rebuild it as often as you like
"IF" this is "not" a duel purpose street use truck....I would definately change for a more offroad oriented gear set
No2 is a great tool and can sometimes be just the trick to get you were you want to go !!!  ;D
2Twisted
Thumper
I only wish I could own a truck that hit 2nd in high lock, damn I guess I do, somebody parked a dually in my yard
THE D&D CREW
