kill switch
Started by michigan maniac, June 12, 2014, 12:55:56 AM
I'm looking into putting a kill switch on my bogger, I won't be running comp bogs or anything like that but I want a secondary shut down just in case, what brand of switch does everyone prefer ?
Wild One
http://www.summitracing.com/parts/sum-g1432/overview/
I like ones like this.
Everything is off!!!
Steve's Oxford Automotive carries, so does Deerfeild
After looking into it more I guess I really need to see if my alt will continue to run when batt power is shut off to determine if I need a 2 pole or 4 pole switch
i use what harbor freight had    been 2 years     works good
a simple single throw toggle to the hot side of the coil will work just fine.
its a 12v low amp circuit.
