95 Camaro won't heat up
Started by stuck in the mud again, January 16, 2016, 10:21:08 AM
Changed lower rad hose topped off the coolant and doesn't heat up.
put in new thermostat and fresh coolant still will not heat up
Engine will not go over 170 degrees no mods done to the car all OEM replacement parts
Quote from: stuck in the mud again on January 16, 2016, 10:21:08 AM
3.4 v6
domedirty2
Should have 2 bleeders one on the bypass tube near kinda behind the water pump and the other on the t stat housing.    sometimes you have to drive them a little with about 2000 to 3000 rpms to get the water circulating and work the ait out .   good luck
Helps alot if you squeeze the hoses with the cap off while its running too
