Projects & Parts => Garage/Tech => Topic started by: OHEARN.2012 on November 05, 2011, 03:20:56 PM
Title: Ford Super Duty Axles??
Post by: OHEARN.2012 on November 05, 2011, 03:20:56 PM
ok for my sas i bought a newer style ford dana 60. it has the bolt lug pattern so ill have to get new rims for it but wat is the matching rear for one of these trucks? and is there any setback or problems with these axles i shud know of?
Title: Re: Ford Super Duty Axles??
Post by: damn_ford on November 05, 2011, 05:12:13 PM
i have a matching rear for ya. out of a 98 superduty 3.73 open diff, 0 miles, came off a pallat from ford.  rotor to rotor no calipers $200
Post by: burl on November 05, 2011, 06:20:58 PM
Usually them fronts ar like a 50 if it came from a f250
Post by: 7387chevynut on November 05, 2011, 07:29:45 PM
The rear axle Ford has used since the mid 1980's in their F250's is the STERLING 10.25 inch, which is a strong axle. only bad thing i've heard about them is parts are expensive, and posi units/ detroit lockers...........not too many options for them, so not many manufactures make em for this axle.........so I've heard.
The fronts in Super dutys are Dana 50's (they are just alittle bit smaller than a 60, but hardly noticable)
I am not 100% sure, but I think the F350's were still made with a 60 front end, but I think those were all dually's.........but again, not 100% sure.
Post by: 4x4xdodgeman on November 06, 2011, 03:29:35 AM
no   ford has two rear ends  10.25 and 10.1/2   the f350 are dana 60 in single wheels. not just dually's
Post by: rangerwheelinmike on November 06, 2011, 03:59:52 AM
f250 superdutey are dana 50s and f350s are dana 50s you just need a rear axle out of superduty f250 or single rear wheel f350
Post by: Blazin40s on November 06, 2011, 04:07:16 AM
So ford one tons srw's have dana 50 front's?
Post by: rangerwheelinmike on November 06, 2011, 06:45:22 AM
not all olny the new f250 superdutys 1998 and up??? the older f250s have ttb 50 and most of the f350s have 60s i think there was 2 years in the 80s where thay use ttb in the f350 ?? not sure tho
Post by: 7387chevynut on November 07, 2011, 12:41:11 AM
1980-1997 F350 all used  leaf spring DANA 60 front axles.
1980-96 F250's used the Twin Traction Beam dana 50 front axle.
The rear f250 350 STERLING rear axle used is the same design used since the 90's and mid 1980s............only difference is Ford started out with a 10.25 ring gear................and then upgraded to a 10.50 ring gear.
Ford also made the STERLING in SEMI FLOAT 8 lug in some mid 80's 3/4 tons.
and also in 6 lug SEMI FLOAT found in late 90's (new body style)  F150's and  full size Explorers or Expeditions?
Post by: rangerwheelinmike on November 07, 2011, 12:47:52 AM
the 6lug was a 9.75 riggear
Post by: 7387chevynut on November 07, 2011, 03:15:30 AM
Quote from: rangerwheelinmike on November 07, 2011, 12:47:52 AM
thats true, but the housing is the same, only difference is it being 6 lug.   GM did the same thing with its semi float 14 bolt in 1988, they offered it in 6 lug and were used under 1/2 ton trucks, and even some light 3/4 ton trucks.
But unlike FORD, GM never offered that in a Tahoe or Yukon like Ford did with their full size Expediton/Explorer.
Post by: OHEARN.2012 on November 07, 2011, 03:32:50 AM
Quote from: damn_ford on November 05, 2011, 05:12:13 PM
pics??
Post by: damn_ford on November 07, 2011, 10:34:29 PM
the 98 and up superduty f250 thru the f450 are the ones with the metric 8 lug bolt pattern
SRW  is a sterling 10.5, DRW is a dana 70
the fronts i had here at the house were dana 70 and the axle joints were as big or bigger than the ones in my 60 front the only reason
i sold them instead of running them is because of the goofy bolt pattern. this rear is the only one i have left
(http://i284.photobucket.com/albums/ll3/tag3312006/ghost/mudtrucks/gun008.jpg) (http://i284.photobucket.com/albums/ll3/tag3312006/ghost/mudtrucks/gun008.jpg)
(http://i284.photobucket.com/albums/ll3/tag3312006/ghost/mudtrucks/gun009.jpg) (http://i284.photobucket.com/albums/ll3/tag3312006/ghost/mudtrucks/gun009.jpg)
(http://i284.photobucket.com/albums/ll3/tag3312006/ghost/mudtrucks/gun010.jpg) (http://i284.photobucket.com/albums/ll3/tag3312006/ghost/mudtrucks/gun010.jpg)
Post by: damn_ford on November 07, 2011, 10:35:42 PM
notice theres not even marks in the paint from u bolts, these came from a wherehouse in dearborn when ford downsize from 300,000 sq ft of storage to 90,000
Post by: OHEARN.2012 on November 07, 2011, 11:25:46 PM
Do I have to have a diff driveshaft for one of these?? And u looking for any trades?
Post by: rangerwheelinmike on November 08, 2011, 03:18:15 AM
you will just need the ujoint flange that bolts to the pinion this not the right one just shows you what it loks like
http://www.dennysdriveshaft.com/img/products/1229393191_1310SeriesFlangeYokefits7.5and8.8inchRearEndsSmallBol.jpg (http://www.dennysdriveshaft.com/img/products/1229393191_1310SeriesFlangeYokefits7.5and8.8inchRearEndsSmallBol.jpg)
Post by: damn_ford on November 09, 2011, 05:13:09 PM
Quote from: OHEARN.2012 on November 07, 2011, 11:25:46 PM
not really trading mud stuff, went to volkswagons. watcha got other than that?
Post by: OHEARN.2012 on November 09, 2011, 08:37:45 PM
Quote from: damn_ford on November 09, 2011, 05:13:09 PM
nothin vw
Post by: damn_ford on November 10, 2011, 11:32:38 PM
open to pretty much anything i think i can resell. guns, tires, dont really want any more axles or t cases though
Post by: OHEARN.2012 on November 11, 2011, 02:58:19 AM
ill look around i got a bunch of stock tires in great condition
Post by: 4x4xdodgeman on November 11, 2011, 07:17:13 PM
that picture you have up is not dana70 it is ford sterling 10 1/2. ford has not used dana rear end sinces the 80's
Post by: damn_ford on November 13, 2011, 06:28:02 PM
if you want to look up my for sale add on that axle youlle see it is a sterling, i thought it was a 70 also but was corrected. the dually rearends were 70, srw were sterling/ford
Post by: OHEARN.2012 on November 13, 2011, 11:10:12 PM
As long as its as strong as a 14 bolt I'm fine with it
Post by: damn_ford on November 15, 2011, 03:35:33 PM
Quote from: OHEARN.2012 on November 13, 2011, 11:10:12 PM
its a big ba$tard with 0 miles, never put in a truck. add callipers and rock with rear disc brakes
Post by: OHEARN.2012 on November 15, 2011, 04:09:42 PM
i want it but id have to find some cash first
Post by: OHEARN.2012 on December 23, 2011, 03:58:57 PM
ehst sre the wheel mounting dimensions of these??
Post by: MUD HUNTER on December 24, 2011, 03:50:03 AM
Quote from: 4x4xdodgeman on November 11, 2011, 07:17:13 PM
Ford used Dana axles in commercial applications such as ambulances and utility trucks until the mid 90's. The Dana 70 in my rig is out of a 92 SRW E450. They stopped using them in standard production trucks and vans in 1991.
The Sterling 10.25 wasn't around very long before they redesigned them as a 10.5. It is a STRONG sumbitch too, and would certainly hold up to a 14 Bolt. For $200, you couldn't go wrong in this deal man.  ++peace
Post by: OHEARN.2012 on December 24, 2011, 02:48:50 PM
Quote from: MUD HUNTER on December 24, 2011, 03:50:03 AM
gonna try getting ahold of him here soon
