Ford Super Duty Axles??
Started by OHEARN.2012, November 05, 2011, 03:20:56 PM
ok for my sas i bought a newer style ford dana 60. it has the bolt lug pattern so ill have to get new rims for it but wat is the matching rear for one of these trucks? and is there any setback or problems with these axles i shud know of?
damn_ford
i have a matching rear for ya. out of a 98 superduty 3.73 open diff, 0 miles, came off a pallat from ford.  rotor to rotor no calipers $200
Usually them fronts ar like a 50 if it came from a f250
7387chevynut
#3
The rear axle Ford has used since the mid 1980's in their F250's is the STERLING 10.25 inch, which is a strong axle. only bad thing i've heard about them is parts are expensive, and posi units/ detroit lockers...........not too many options for them, so not many manufactures make em for this axle.........so I've heard.
The fronts in Super dutys are Dana 50's (they are just alittle bit smaller than a 60, but hardly noticable)
I am not 100% sure, but I think the F350's were still made with a 60 front end, but I think those were all dually's.........but again, not 100% sure.
chevvv
4x4xdodgeman
no   ford has two rear ends  10.25 and 10.1/2   the f350 are dana 60 in single wheels. not just dually's
rangerwheelinmike
f250 superdutey are dana 50s and f350s are dana 50s you just need a rear axle out of superduty f250 or single rear wheel f350
So ford one tons srw's have dana 50 front's?
rangerwheelinmike
not all olny the new f250 superdutys 1998 and up??? the older f250s have ttb 50 and most of the f350s have 60s i think there was 2 years in the 80s where thay use ttb in the f350 ?? not sure tho
7387chevynut
1980-1997 F350 all used  leaf spring DANA 60 front axles.
1980-96 F250's used the Twin Traction Beam dana 50 front axle.
The rear f250 350 STERLING rear axle used is the same design used since the 90's and mid 1980s............only difference is Ford started out with a 10.25 ring gear................and then upgraded to a 10.50 ring gear.
Ford also made the STERLING in SEMI FLOAT 8 lug in some mid 80's 3/4 tons.
and also in 6 lug SEMI FLOAT found in late 90's (new body style)  F150's and  full size Explorers or Expeditions?
chevvv
rangerwheelinmike
7387chevynut
Quote from: rangerwheelinmike on November 07, 2011, 12:47:52 AM
the 6lug was a 9.75 riggear
thats true, but the housing is the same, only difference is it being 6 lug.   GM did the same thing with its semi float 14 bolt in 1988, they offered it in 6 lug and were used under 1/2 ton trucks, and even some light 3/4 ton trucks.
But unlike FORD, GM never offered that in a Tahoe or Yukon like Ford did with their full size Expediton/Explorer.
chevvv
Quote from: damn_ford on November 05, 2011, 05:12:13 PM
pics??
damn_ford
the 98 and up superduty f250 thru the f450 are the ones with the metric 8 lug bolt pattern
SRW  is a sterling 10.5, DRW is a dana 70
the fronts i had here at the house were dana 70 and the axle joints were as big or bigger than the ones in my 60 front the only reason
i sold them instead of running them is because of the goofy bolt pattern. this rear is the only one i have left
damn_ford
notice theres not even marks in the paint from u bolts, these came from a wherehouse in dearborn when ford downsize from 300,000 sq ft of storage to 90,000
Do I have to have a diff driveshaft for one of these?? And u looking for any trades?
rangerwheelinmike
you will just need the ujoint flange that bolts to the pinion this not the right one just shows you what it loks like
http://www.dennysdriveshaft.com/img/products/1229393191_1310SeriesFlangeYokefits7.5and8.8inchRearEndsSmallBol.jpg
damn_ford
Quote from: OHEARN.2012 on November 07, 2011, 11:25:46 PM
not really trading mud stuff, went to volkswagons. watcha got other than that?
Quote from: damn_ford on November 09, 2011, 05:13:09 PM
nothin vw
damn_ford
open to pretty much anything i think i can resell. guns, tires, dont really want any more axles or t cases though
ill look around i got a bunch of stock tires in great condition
