Projects & Parts => Garage/Tech => Topic started by: spr_chicken on January 02, 2012, 07:30:20 PM
Title: HELP... wheels will not come off
Post by: spr_chicken on January 02, 2012, 07:30:20 PM
I have a 1989 3/4 ton 4x4 Suburban that I can not get the rear wheels off of. A little over a year ago I had new tires put on it. I had to use a breaker bar and a 5 ft pipe to get the lug nuts off. I have had the front wheels off to do the front brakes. I went to do the rear brakes and rotate the tires and I can not get the rear wheels off. They seem to be stuck on the lugs. They are alcoa aluminum rims and will not budge. I tried a pry bar, 10 lb hammer, and hear without any luck.
I have tried to call the place that put the tires on and just get an answering machine. I left a couple of general messages for them to just call me and one with a little detail on my problem.  I do not want to just drive there because it is a 1/2 hour away from me and the truck needs rear brake bad.
Does anyone have any other idea on how to get the rear wheels of? The rear axle is a c-clip corp 14. I am at the point where I might try pounding the wheel studs out...
Title: Re: HELP... wheels will not come off
Post by: Chevy Racer on January 02, 2012, 07:40:29 PM
I had an issue like that and had to climb under the truck and hit the inside of the rim with a sledge to break it loose.  The center hole is a tight fit and can corrode and make it even worse.
Post by: marshall on January 02, 2012, 07:44:26 PM
20 lb. hammer, than anti-seize
Post by: spr_chicken on January 02, 2012, 07:49:22 PM
Quote from: marshall on January 02, 2012, 07:44:26 PM
LOL I used a ton of anti-seiz on the front after I did the brakes...
Quote from: Chevy Racer on January 02, 2012, 07:40:29 PM
I tried hitting the rim, tire, and brake drum. I even tried an air hammer, thinking it might vibrate it loose.
Post by: 4x4xdodgeman on January 02, 2012, 07:51:47 PM
I have heated center of wheel and axel. just a little. and then go under hit the tire with sledge and turn the wheel some.  when going together use anti-seize it.
Post by: spr_chicken on January 02, 2012, 08:04:01 PM
Quote from: 4x4xdodgeman on January 02, 2012, 07:51:47 PM
I tried heat...
We even tried the pry bar while hitting the tire with the sledge hammer while it was hot. I worked at it for over 3 hours.
Post by: dirtydog on January 02, 2012, 08:10:37 PM
put the front back together n drive it around a short distance with loose lug nuts but keep an eye on them. just an idea u dont have too try it
Post by: spr_chicken on January 02, 2012, 08:20:55 PM
Quote from: dirtydog on January 02, 2012, 08:10:37 PM
I left the lugs loose and drove the truck in circles and up and down my dirt road. I figured that would have been my best bet being the truck is so heavy
Post by: dirtydog on January 02, 2012, 08:40:25 PM
Quote from: spr_chicken on January 02, 2012, 08:20:55 PM
==dn ==please
Post by: BIG DOG on January 02, 2012, 08:41:49 PM
put the tires back on and take it to your local place for a tire rotation   lol    come home then do the pads   ..       bottom line beat the piss out of it and keep turning the tire   leave a lug nut on loose to catch it when it comes loose.          good luck
Post by: spr_chicken on January 02, 2012, 08:43:15 PM
Quote from: dirtydog on January 02, 2012, 08:40:25 PM
==dn ==please
I did that last night, so we will see if it worked later when I try getting them of again... LOL
Post by: spr_chicken on January 02, 2012, 08:44:43 PM
Quote from: BIG DOG on January 02, 2012, 08:41:49 PM
I thought about taking the truck to get an oil change and get the tires rotated... LOL
Post by: ToughBowtieTruck on January 03, 2012, 01:17:53 AM
Use an any-angle bottle jack to put pressure on the rim, use a block of wood anchored to the opposite wheel or spring . . .
But wait!! If you have a full float axle, you CAN just take the wheel and hub off as an assembly, if you don't have or care to destroy the center caps . . .
Post by: RIP_K52007 on January 03, 2012, 01:21:06 AM
take it to discount tire and tellem ur back tires are leaking... they will take them off for you loll  or soak it in wd40 and let it sit then go at it the next day with the sledge hammer  ;D
Post by: RIP_K52007 on January 03, 2012, 01:24:43 AM
and anti seize is a big no no... if you get it between the wheel surface and the hub when you tighten the lugs it is like hydraulic pressure between the two surfaces, doesnt let the wheel tighten all the way up.    Also putting it on the studs is not a real good idea, it does the same thing between the surface of the lug nut and the seat on the wheel. (it can actually make the threads strip off the stud easier if you are using a impact).. The best thing you can do is clean both surfaces up as good as you can (we use wire brushes and 3m buffing pads) and just make sure you take the tires off every 3 months/6,000 miles (like for a rotation). That way you can keep the hubs clean and dont have to worry about running into this problem in the future.
While you have the truck in the garage it isnt a bad idea to drop the spare tire check the air in it and WD40 up the winch cable so it doesnt rust up and not come down when you need it.
Post by: Wild One on January 03, 2012, 01:44:50 AM
The Works toilet cleaner. let it soak for a while, add a little more, soak, ect.
It will eat the corrision caused by aluminum against steel.
Used it on semi-trailer rims, came off with small pry-bar
Post by: burl on January 03, 2012, 02:47:54 AM
Clr also
Post by: 7387chevynut on January 03, 2012, 02:58:04 AM
I had this problem on my 86, but it was only the right front tire. I used a 4x4 post and sledge hammer, and put the long end of the post up against the rim, and them beat the piss out of it, she finally gave way.
You probably know this already, but dont hammer on the rim itself with the hammer, I try not to do this with the tire itself. Remember, beating a wood block against a rim wont hurt it
Post by: spr_chicken on January 03, 2012, 04:05:05 PM
I talked to the place that put the tires on and they said they would charge me to get them off. So there was no point in driving there for nothing anyways...
That will be the last time I buy anything from there again. I've baught several lift kits, wheels, tires and other parts from them in the past...
Post by: camok10 on January 04, 2012, 03:10:48 PM
ive used a porta power befor between the wheels and it worked just keep the lugs on so once ones loose you can still get the other
Post by: chevyjake on January 04, 2012, 03:59:20 PM
Pull the lugs off shoot some PB blaster on the studs to soak the back side of the wheel, let it sit and either smack it with a sledge hammer or drive it around in circles/ back and forth. just be careful not to take the wheel to the shin when your hitting it with the sledge.
Good Luck..
Post by: OHEARN.2012 on January 04, 2012, 04:29:02 PM
try jumping it like the dukes of hazzards did??
Post by: old school truck dude on January 04, 2012, 10:21:21 PM
The lugs aint holdin it, the center is. Soak the center real good, use a wood block and sledge on the back side of the rim or a porta power. You can also use a bottle jack or a high lift jack or whatever ya got (I use a scew jack for just about everything) and wood block if you can find a spot to push from or possibly chain it to the axle housing some how. Get some pressure on it as far out to the outside edge as possible then smack it. It WILL come off. Clean it all up real good once its off and put some GREASE not oil on the center so this dont happen again. ;D
Post by: 4x4xdodgeman on January 05, 2012, 04:23:18 AM
I got!!!!    get realy pissed off and do everything every body said!!!
Post by: OHEARN.2012 on January 05, 2012, 04:25:36 AM
Quote from: 4x4xdodgeman on January 05, 2012, 04:23:18 AM
try jumping it first
Post by: woody11769 on January 05, 2012, 04:57:19 AM
Good luck it sucks when it happens like everyone said you need a bigger hammer it'll come
Post by: rangerwheelinmike on January 05, 2012, 05:20:50 AM
take the lugs off put a chain around the rim and hook it to another truck put in in 4low and stand on it?? loll
Post by: four_by_ken on January 07, 2012, 10:10:46 PM
Did it ever come off?
Post by: WHITE KNIGHT on January 07, 2012, 11:21:30 PM
p b blaster will work if you give it time like over night sleepyy
Post by: ToughBowtieTruck on January 08, 2012, 04:56:53 AM
Quote from: four_by_ken on January 07, 2012, 10:10:46 PM
I know, this suspense is killing me !!!
Post by: spr_chicken on January 08, 2012, 08:47:43 AM
Quote from: ToughBowtieTruck on January 08, 2012, 04:56:53 AM
No not yet...
Post by: spr_chicken on January 08, 2012, 08:48:25 AM
Quote from: rangerwheelinmike on January 05, 2012, 05:20:50 AM
I'm considering this...
Post by: spr_chicken on January 08, 2012, 08:49:55 AM
I tried using a come along attached to a tree and hiting the wheel with a sledge hammer. I put a jack stand under one side and I pulled the truck off of it once. I'm affraid i'm going to break the c-clips or the axle shafts.
I am going to try again. I am going to do the same thing, but this time I am going to let the air out of the tire so I can hit the rim better. If that doesn't work I am going to pull the axle apart and try to pressing the wheel studs out.
Post by: RIP_K52007 on January 08, 2012, 02:28:15 PM
you could do the opposite, max the tire pressure out so the tire is not so bouncy vs the hammer lol if they are load range D you could probably put 65psi in them ==dunno
put the lug nuts half way and go beat the p00 out of it til it falls off ==roll
Post by: Hammerlane on January 08, 2012, 02:47:42 PM
add some heat.. propane torch type..
heat up around the center n' lugs..
Post by: rangerwheelinmike on January 08, 2012, 03:41:25 PM
Quote from: spr_chicken on January 08, 2012, 08:49:55 AM
wow I guess I would take the lug nuts half way off and go beat on it
Post by: Bigolcummins on January 08, 2012, 05:31:52 PM
so its locked itself up in the center hub pretty much?
Post by: J.C. on January 08, 2012, 05:36:35 PM
Hell by now i woulda taken out the c clips ++peace
Post by: Crazymays77 on January 08, 2012, 09:09:22 PM
once you get it off clean the center of the rims so there is more clearance there. that way it doesnt happen again.
Post by: Newbie on January 08, 2012, 11:31:50 PM
Quote from: Cliff on January 07, 2012, 11:21:30 PM
pb is the way to go with a torch! :)
Post by: betterbeaters on January 10, 2012, 01:07:32 AM
bigger hammer!
Post by: OHEARN.2012 on January 10, 2012, 03:37:31 AM
torch off the rim
Post by: Bo Duke on January 10, 2012, 03:41:19 AM
put the lug nuts on loose and drive it around the yard drive way or whatever and try taking it off again..
Post by: spr_chicken on January 10, 2012, 07:08:47 AM
I put the lug nuts on loose and went for a 30 min hell ride through the field (it was just all tilled under and half frozen) next to my house. I've been working on my ford and a few other trucks. So the suburban has just been sitting. I'm going to try using a come along attached to a tree again and this time let the air out of the tire to hit the rim. If that doesn't work I am going to pull the axle apart and try to pressing the wheel studs out.
I've tried just about everything suggested here except using a truck to pull on the rim. I've been reading horror stories about the alcoa rims I have. I will be opening the wholes in the rims up when I finally get them off. Then when I get my taxes back I will be buying steel rims and beating the hell out of the alcoa's with the 13# sledge hammer that wouldn't get them off... LOL
Post by: black07ss on January 10, 2012, 10:16:45 AM
Quote from: OHEARN.2012 on January 04, 2012, 04:29:02 PM
I like this idea!!  I would pay to see it!!
Post by: RIP_K52007 on January 10, 2012, 03:39:23 PM
get a tire bar and change the tire on the wheel on the truck ==roll ==dunno
Post by: old school truck dude on January 10, 2012, 10:26:24 PM
Exactly how Ive done a bunch of tractor and equipment tires - it works!  ==roll
Post by: spr_chicken on January 12, 2012, 07:22:03 PM
I just pulled the truck around sideways by the rim with the lug nuts loose. I am just going to have to pull the axles out with the drums and wheel attached. I surrender... LOL
Post by: old school truck dude on January 12, 2012, 08:04:21 PM
Hit it harder ==roll
Post by: spr_chicken on January 12, 2012, 08:57:36 PM
Quote from: old school truck dude on January 12, 2012, 08:04:21 PM
I think leaving 10ft of slack in a 30ft tow strap and flooring it is about as hard as I want to hit it. I was pulling the suburban sideway a foot and a half each time I hit it...
Post by: spr_chicken on January 12, 2012, 09:05:24 PM
hmmm... My 11 year old son just came over to me and said "dad why don't you just put those axles under it" pointing at the corp 14 and dana 60 laying on the floor of my pole barn. They are for my next build but i'm kind of thinking about it...
Post by: RIP_K52007 on January 12, 2012, 09:27:53 PM
Quote from: spr_chicken on January 12, 2012, 09:05:24 PM
smart kid ==roll
Post by: old school truck dude on January 12, 2012, 09:36:01 PM
For a last attempt before u pull the axles, try  proppin up a bottle or screw jack behind the rim n get some pressure on it. Next, put your strap on it and chain the truck to a tree or somethin so it wont move and get a hard pull started, then hit it with ur sledge n wood block, also put some heat to it while ur gettin this all set up. Snatchin it with a strap aint gonna do much cuz the strap  stretches some - wish u were closer Ive run into this before and always got them loose.
Post by: RIP_K52007 on January 12, 2012, 09:54:39 PM
call fire dept tell them to bring the jaws of life ==roll
Post by: ToughBowtieTruck on January 13, 2012, 12:22:25 AM
Dude, you need to Youtube these attempts before you give up!
Post by: BigFrank on January 13, 2012, 01:08:36 AM
what ya need is a big dude to swat em loose   swing the sledge like a golf club pop em right off ==np
Post by: gator82 on January 13, 2012, 01:21:56 AM
I got an idea, take it to a discount tire, pay $25-35 for a rotation and tell'em ta call when its done. You could also run it around and do some hard stops and get the whole rotor hot then try hammering it off.
Post by: RIP_K52007 on January 13, 2012, 02:02:08 AM
Quote from: gator82 on January 13, 2012, 01:21:56 AM
We do free rotations lol! just dont bring it to the burton store.. please. ==roll
Post by: spr_chicken on January 13, 2012, 05:11:17 AM
Quote from: lilred on January 13, 2012, 02:02:08 AM
I do have to run that way to get some parts with a friend... ==dancinbanana
Post by: old school truck dude on January 16, 2012, 11:34:17 PM
Lilred, you got any vacation days built up yet? You might need to take one..  ++peace
Post by: 85cHeavyMetalBogger on January 17, 2012, 01:37:38 AM
cut the centers out?????
Post by: Colorado on January 17, 2012, 02:26:26 PM
My  ==2cents:   If the wheels are still stuck on, just drive some bad pothole roads with lugs way loose. Seriously. Something has to eventually give.
==ec
Post by: OHEARN.2012 on January 17, 2012, 04:05:10 PM
Quote from: Colorado on January 17, 2012, 02:26:26 PM
==ec
drive through genesee county all their roads suck!
Post by: cvan on January 17, 2012, 04:11:15 PM
Get a 20 pound sledge and beat the sh*t out of it
Post by: RIP_K52007 on January 17, 2012, 04:30:25 PM
Quote from: OHEARN.2012 on January 17, 2012, 04:05:10 PM
==ec
he already did that..
Quote from: spr_chicken on January 10, 2012, 07:08:47 AM
Post by: Colorado on January 17, 2012, 10:13:39 PM
Ya, 30 minutes. I've seen people at bars ride the bull longer than that!  ==roll
Post by: Goldeneagle on January 22, 2012, 02:33:16 PM
if i read it right you are planning to replace the rims in the future..   drill and tap the rim and run a couple bolts in the holes bottoming out on the drum.  just a thought..   both holes drilled on one side of the hub.
Post by: gator82 on January 22, 2012, 04:05:31 PM
Did you get this figured out yet or have you knocked yourself unconscious in the process of wheel removal........ ==roll ==roll ==roll ;D
Post by: Hammerlane on January 22, 2012, 04:19:18 PM
sounds like its time to pull the C clips n' do it the hard way.
Post by: 72 Bogger on January 30, 2012, 10:37:44 PM
well ive read the whole post and still dont know if you got them off
. did you and how did you if you did?
Post by: old school truck dude on January 31, 2012, 12:53:10 AM
Yes, we have alot of typing involved here and so we'd like an update please ==roll
Oh yeah and ==suxnopics
                    ==jk ;D
Post by: J.C. on January 31, 2012, 03:54:33 AM
Quote from: gator82 on January 22, 2012, 04:05:31 PM
Lol
Post by: old school truck dude on February 02, 2012, 12:22:56 AM
Quote from: J.C. on January 31, 2012, 03:54:33 AM
Lol
Maybe the wheels finally fell off while he was drivin it and he hit a tree and is unconscious loll
This is one for the books, by gosh.. We need a "Best of WEGOTMUD" section!
Post by: BIG DOG on February 02, 2012, 12:35:00 AM
lol
Post by: 4x4xdodgeman on February 02, 2012, 04:58:51 AM
we are waiting here!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post by: gator82 on February 02, 2012, 05:25:38 AM
Quote from: 4x4xdodgeman on February 02, 2012, 04:58:51 AM
X2
Did some investigation work and this is what I found: Last Active:    Today at 12:11:29 AM (YEAH, I'M.......THAT GOOD).  Must be Aliens, oooooooohh, hope he's alright, heard some stories about them guys,  NOT GOOD!!!!! And they have a fetish with underwear and socks, mine are always missing.
Post by: spr_chicken on February 02, 2012, 08:00:06 AM
I did take to Reeds Tire in Holland and they could not get them off either. I have not messed with it since. I started a new job. I also have a ton side jobs and a few other projects of my own to get to first. So I won't even get it in the pole barn until after that stuff is done. I am either going to pull the axle apart of just torch the rims off the studs. I'm thinking about putting tons under the burban (thanks to m sons input) so who knows.
Post by: reaper1986 on March 01, 2012, 02:24:24 PM
have you tried using a brake drum remover? looks like a giant three jaw puller. The center screw should just force the rim off, If not, it's will mangle the center hub enough to wedge a pry bar under it.
Post by: BLAZIN SKIDDY on March 01, 2012, 03:11:01 PM
leave the lugs loose and do some donuts
Post by: BUDGETBOGGER03 on March 01, 2012, 05:52:15 PM
Quote from: BLAZIN SKIDDY on March 01, 2012, 03:11:01 PM
maybe try to jump it a few times lmao
Post by: 72 Bogger on March 01, 2012, 10:14:13 PM
Quote from: old school truck dude on January 31, 2012, 12:53:10 AM
                     ==jk ;D
Post by: old school truck dude on March 02, 2012, 04:39:00 PM
Id like to try to get them off of there for you, seems simple to me  ;D
Post by: RIP_K52007 on March 02, 2012, 05:54:22 PM
Put 10 bux in a can n start charging $5 a person to try to takem off and offer the $ can to the one who gets it ==roll ==dunno
Post by: Hammerlane on March 03, 2012, 02:57:13 PM
Quote from: lilred on March 02, 2012, 05:54:22 PM
That's the best solution I've heard so far. applaudd ==roxx
Post by: mudbillyredneck on March 04, 2012, 04:34:07 PM
That would work around here .....only problem is they'd drink $100 worth of my beer trying ......LOL !
Post by: betterbeaters on March 04, 2012, 05:17:42 PM
Quote from: mudbillyredneck on March 04, 2012, 04:34:07 PM
lol
Post by: old school truck dude on March 22, 2012, 07:20:04 PM
Are they still stuck on there..? ;D
Post by: Jthomas on March 22, 2012, 08:40:49 PM
let me touch it, with my bad luck the entire truck will fall apart.
Post by: spr_chicken on May 02, 2012, 12:12:15 AM
Thanks to two of my friends the rims are off my suburban. It only took 2 trees, 3 ratchet straps, a big sledge hammer, and Rich jumping on the straps to get them off.
And to Truck and Van Specialties you can kiss my azz. The lugs where tightened down so hard that the rims were pressed onto the studs. There was aluminum stuck on the studs after the rims came off.
I had given up trying since I found out I had hodgkin's lymphoma cancer. My budies said they would get the wheels off for me and get my rear brakes fixed.
(http://i294.photobucket.com/albums/mm117/spr_chicken/drum.png)
(http://i294.photobucket.com/albums/mm117/spr_chicken/rim1.png)
(http://i294.photobucket.com/albums/mm117/spr_chicken/rim2.png)
Post by: Blazin40s on May 02, 2012, 12:13:52 AM
Wow man, glad they came off.  Sorry yer sick tho
Post by: BigFrank on May 02, 2012, 12:25:00 AM
Quote from: Blazin40s on May 02, 2012, 12:13:52 AM
prayy prayy prayy  hope ya get better
Post by: old school truck dude on May 02, 2012, 12:29:17 AM
Wow, that's rough.. Hope ya get to feelin better and we're all here for ya dude!!
Post by: spr_chicken on May 02, 2012, 12:43:49 AM
thanks... I start chemo thursday. Well if priority health gets my treatment approved by then. I have stage 2. I found a lump under my left arm pit. Then the pet/ct scan found more under my left shoulder and a small amount in my chest on the left side.
Post by: Blazin40s on May 02, 2012, 02:55:37 PM
How big of a lump?
Post by: BUDGETBOGGER03 on May 02, 2012, 03:17:33 PM
glad u got the wheels off get better bud
Post by: spr_chicken on May 03, 2012, 01:29:57 PM
Quote from: Blazin40s on May 02, 2012, 02:55:37 PM
How big of a lump?
there are 2 lumps under my arm pit. 1 is golfball size and the other is twice as big. the other 2 spots are small and i cannt feel them.
Post by: Blazin40s on May 03, 2012, 03:09:41 PM
That sux man.  Hope all goes well 4 ya!
Post by: ToughBowtieTruck on May 04, 2012, 03:12:32 AM
Want to sell those wheels? They'd make my trailer match the tow rig!
I can dig up stocks to throw in on trade . . .
