Project brownie update page 2
Started by camok10, October 10, 2012, 04:20:25 AM
BC775
you can build it for a 1/3 of that cost if you go with the boiler tube
camok10
Ya I just want to get it together for right now though. I can always take measurements and stuff to with the leaf springs in and that way it will be perfectly square too. I think this winter ill get it together and refine it next
84 c10 project
82 c10 beater diesel
camok10
Well found a front axle a low pinion 44  out of a 77 ford 250 today, also got the stuff I needed to re mount rear leaf springs. And took a pic today of the fleet of 88-98's I've got starting along with my lonely 84 in the back ground
84 c10 project
DAGEN
The body is in good shape by the look's for the most part. Front axle location prolly explain's why whoever started building decided to get rid of it lol. Look's like youll have a good build and am looking forward to this.
Never ending project's. 97 chevy sas'd 12'' lift lot's of goodies.
BC775
What you plan on running for tires?
camok10
I'm hopeing it'll go smooth just gotta work on saving up that money. And for tires I'm not Shure yet something in the 36-38" range maybe some mill surplus on a 16" till I can get some tsl's. this week here it's probably getting sat on the 35" procomps on my blue truck.
84 c10 project
camok10
Well got looking at how the spring hangers go on I know the horns are a little beat up from an accident but it looks like my frame may be out  ==pissed I'm going to measure my trucks and my Tahoe and compare when I'm home again. Looks like my brown truck may be getting the Lovin of a sas instead
84 c10 project
camok10
Friday im Ordering these 6.5" super shackles
http://www.offroaddesign.com/catalog/hdREARshackles.htm
And this 4" shackle flip
http://offroaddesign.com/catalog/shacklekit.htm
If I've done the math right that should net me about 6" of lift and will make up the other 4" with a block
84 c10 project
Should put those pics on Pirate 4x4's hack fab thread. That's some uhhh "creativity" there. ==roll
camok10
It came from out your way lol Cochran and 5 point area. But this is now project brownie the Tahoe is now just parts with a jungle gym under it if any one wants any thing off it let me know I'm use ong the rust free front clip and front doors on my 97
84 c10 project
camok10
Well the tahoes frames out by about 1-1/2" so it's getting parted so time to tear apart a perfectly good truck that just needs a rear end
97 Chevy z71 Vortec 350 true duals with flows hypertech k&n filter trick flow t.b. space and hopefully by spring a 6 lug sas with a 77 ford 44 and factory 10 bolt may try and find a sf 14 for it but that can always be changed later
Already have the front axle a set of 6 lug outer, ord shackle flip and 6.5" super shackle are on there way going to also put in a 4" block and ord 0 rate add a leaf to net 10" of lift rear. Front is yet to come but going to be ord sas kit, 8" 73-87 front spring. Along with the ord cross over steering set up an a ried racing/ dedinbear flat top knuckle. After that all that will be left will be to figure out shock length and mounting, and figure out length for a set of 81-87 ext brake lines since I will be using calipers for that year truck should be a blot on and go there. Hopeing to be out of this for under 3000 including truck purchase price. Minus wheels tires and gears it should be very do-able
The truck
84 c10 project
camok10
Well the rear lift is in, going to ad an add a leaf and be at 7" and use my 4" springs up front for 7"
84 c10 project
