no run
Started by kasper, January 14, 2010, 10:55:14 PM
bigdawg41
if its been sitting for more than 30 days with gas in it i would think that its bad gas . the fuel we get nowdays breaks down really fast. last spring my bogger started up just fine the next week it wouldn't run . had to pull the carb apart and clean out the jello from inside.
kasper
thanks i will let you guys no
BigDogRacing
dump fresh gas downt the carb it would fire eaven if the gas in the tank went bad and gummed it up
73chevytruck
did you get this running again yet?
Quote from: n kasparian on January 18, 2010, 06:41:58 PM
i would not fire off starting fuild i truns over like it wonts to fire but no go
I'm with F4x4C. I think the wires are on in the wrong order or the distributor came loose and turned. If it won't fire off ether, it's not a fuel problem. If you're getting spark in through a tester I don't think it's the coil. Check your wires, they might be on 180 degrees off. Check timing. I bet that's gonna be your problem.
kasper
no not yet guys i have been working 6 days a week i got a new job and it is going well i will be getting back on the truck soon
tnbt78
module normally wont stop it from starting just dies the more rpms you turn. we dont run a alt on my racecar and we only charge the battery for a couple hours befor we race.
Dodgeman51
u have 2 of the basics the one your missing is compression do u have compression.
show me what its got, put the tires threw the fenders.
X2 on bad gas...try dumping some fresh gas down the carb!
Might be low compression from the cylinders rusting up sittin so long. Maybe pull all the plugs, spray wd-40 in all the holes and crank it over till it turns real freely, then put new plugs in check firing order and THE POSITION OF THE ROTOR IN RELATION TO THE CAP? ??? ;D
kasper
