Custom Bent / Wild Time Fab. (new web site)
Started by wildtime, July 22, 2007, 01:38:38 PM
wildtime
Custom Bent Exhaust / Wild Time Fabrication
is your ROCKWELL CONNECTION PLUS
COME GET YOUR ROCKWELL AXLES AND PARTS from WildTime Fabrication
Owned and operated by my self since "94" Home Based shop that offers all exhaust repairs,  truck lifts & accessories, and custom 4x4 fabrication   Just north of Battle Creek about 8 miles (14865 North Ave  Bellevue Mi 49021)     PHONE #  269 758 3857
We also have or can get any Rockwell Parts you could need for your 2.5 & 5 ton axles, and the parts to put them in your truck or build a truck from the ground up.
[attachment deleted by admin]
"WTF"
RUN your TRUCK NOT your MOUTH
wildtime
Just added some new fabrication equipment to the shop.  (YOUR FABRICATION JOB DOES NOT HAVE TO BE TRUCK RELATED)
    ( 5' x 10' CNC Plasma Table)
   Now able to CNC CUT, wheel centers, four link brackets, shock tabs, mounting plates, gussets, flanges, ect. Almost anything out of flat steel that I can draw first in a cad program.
     (55 Ton Iron Worker)
   Now able to shear flat steel to 14" wide & 4x4 angle, Punch holes up to 1& 1/16" in up to 5/8 " plate, custom notching/coping, and
   Press Brake (Bend) up to 5/16" x 12" material
     ( Thick Wall Tube Bender )
   Now able to correctly bend DOM tubing in   1", 1.25", 1.5",1.75"and 2" sizes for any of your needs such as Bumpers, Shock Hoops,
   Cages, Complete Frame, or any other application you can think of.
           These services will be availible along with the everything we were already doing, So if there is ANYTHING you'd like for your truck,
   AFTER MARKET OR CUSTOM BUILT   CALL:
        269 758 3857 or 269 317 4082
                                                         CustomBent Exhaust LLC  /  Wild Time Fabrication
"WTF"
wildtime
Also now offering all maintenance and rebuild parts for 2.5 ton and 5 ton Rockwell Axles
  Seals, Bearings, Gaskets, Axle Shafts, Ujoints, Any and All Parts.
Also Custom Rockwell parts
  Pinion Brakes, Four Link Brackets, Weld on Lift Blocks, ect.
Military Truck Parts Available
"WTF"
wildtime
#3
Here are some inverted 4 link brackets for 2.5 ton Rockwell axles, CNC CUT from 3/8" plate ready to be finish drilled to size for your heims, and welded to the axle.
These will sell in sets Enough for both sides of one axle for 160.$  if you let me know what size you need the holes drilled to That can be done, for a fee, before they are shipped
 "WildTime Fabrication"  269 317 4082
Other  Brackets AVAILABLE or if ya need something special let me know
These are weld on lift blocks for Rockwell Axles Many Hiegths and Angles Available.  These are 6" with 8 degree angle
SCS   T-Cases and Nitrogen Shocks  Available by special Order ONLY
Wheel Centers CNC cut  to your specs / (size)
This one is 1/2" plate 23&1/2" OD and fits 2.5ton Rockwell
Check Out the EXO CAGE in projects Built by "WTF" for Slymer   Thanks Slymer
Rockwell Off Road Pinion Brakes
"WTF"
wildtime
#4
Patterns cut into wheel centers available upon request
P.S.  call "WTF" for the best price around
             269 317 4082
"WTF"
huntermrh
How much would you charge to put 8 lug centers in a 6 lug rim? With and without centers. huntermrh@charter.net
wildtime
"WTF"
wildtime
Just put up a new site with some parts, prices, & pics  check it out http://wildtimefabrication.com/index.html
"WTF"
wildtime
"WTF"
wildtime
"WTF"
ballistics-10
brought my rocks and suspension stuff and just got my exhaust done.. great parts, great work, great prices!!!
wildtime
#12
"WTF"   "OPEN"
"WTF"
once the my Nova is done....ill be getting a hold of you for my new "secret " project.  heres a ==bump in the mean time.
wildtime
"WTF"
thanks for adding my truck to ur website dave ill get you some new pics tomarrow  ==wgm ;D
wildtime
"WTF" has a brand new industrial  CNC  Plasma  Table  on the way, should be in the shop monday morning 7/19/2010   I can't wait. The old table was hit by lighting last month.
"WTF"
wildtime
5x10 TorchMate Water Bed Cutting Table  Plasma   (OR)    Oxy Fuel    anything thicker than 1" is cut with Oxy/Fuel (torch) can cut 3" if needed,   haven't used the Oxy fuel yet!!!LOL
"WTF"
2trackr
dave did my exhaust on my HD, and i just picked up some rockwell parts, great guy to deal with.
wildtime
Just IN!!!!!  "WTF"  now has 2.5 inch bender dies for DOM tubing.   Hope to get some work for these, LOL, just the die set was 880$
Able to bend 1, 1.25, 1.50, 1.75, 2, 2.5 inch DOM Tubing and  1.5, 1.75, 2, 2.25, 2.50, 3 inch exhaust tubing.
"WTF"
