intake ??
Started by THAT MUDFIT GUY, July 10, 2008, 10:39:43 PM
THAT MUDFIT GUY
i have a 91 motor (new style heads) and a older style intake and have been told i can drill out the center bolt holes to make it fit i was wondering if this is true and will it cause any leaks  and if it is still usable on a older style block  any  help would be appreciated  thanx   derek ??? ??? ???
THAT MUDFIT GUY
Swampthing
they do make a intake.. to do just for doing that...bolt in.. no drilling required
82 scrambler ,blazer frame ,small block.It runs everything from 33's-44's....83 cj7.full size chevy axles..48 inch terra tires.. 83 cj7... purple. 350 chevy toyota axles,37 inch boggers..have fun and keep the rubber side down.. Swampy
Kodiak450r
you can use your intake. grind out the center bolt holes. have done this on more then 1 occasion and no problems ever happened. you can buy the proper intake from sumit or jegs. heres summits version. http://store.summitracing.com/partdetail.asp?part=SUM%2D226016&autoview=sku
"I just hate stupid people, i think they should have to wear signs that say "i'm stupid". that way you wouldn't rely on them would ya, you wouldn't ask em' anything" Bill Engvall
THAT MUDFIT GUY
JEGS AND SUMMIT = MORE MONEY IM CHEAP  LOL
Econo-box from Hell
If you are serious about using Vortec heads on an older block you are wasting your time messing with the old style intake.  The intake ports are taller on a Vortec head so you really wouldn't gain any performance using an older intake with the newer heads.
==nw geoo ==wn
91's weren't vortec they were just center bolt ;)
Econo-box from Hell
Quote from: Mudbuster on July 19, 2008, 01:11:37 AM
You are correct.  After rereading the post I see what is going on.  Since these are just TBI heads then it doesn't matter if you drill out the center holes.
==nw geoo ==wn
Trucker
i have done this my self and it works but test fit and gring little at a time so you don't take to much out
if your not the lead dog the view never changes
