shift kit question
Started by chevystudz7105, July 16, 2008, 10:33:57 PM
chevystudz7105
here hopefully sometime soon im going ot be rebuilding my 350 trans i have to replace the manual trans thats in my muddin truck.  im going to be running a reverse manual valve body.  some people ask me why i want to do that and the reason is my brother in law has that in his muddin/silverlake truck and i really like how i can still make the truck shift when i want it to but not have to have a clutch.  anyways im wondering about shift kits for it.  the guy that does all my trans for me  mentioned going with a b&m and also a trans go.  but with me running a reverse manual valve body  will these shift kits still work?  or do they make special ones for the reverse pattern?  i havent ordered the valve body yet  or else id just ask the techs at summit about it, but i figured id see if anyone on here knew
thanks for any help
Squirell
valve bodies dictate which way the tranny shifts, shift kits reroutes the fluid through it to make a shift more snappier. so they will both work together. and a reverse valve body goes  PRN12D where a normal one goes PRND21 hope this helps and if i have something wrong someone please help
Theres no need for a shift kit. The manual valve body will only shift when you tell it to. It will also raise the line pressure.
chevystudz7105
i didnt think htere was a need for a shift kit either seeing as im going to be telling the trans when to shift.  i was just curious about it seeing as what my trans guy told me he was going to do, but he did get a lil  puzzled look about it when i told him i was runnin a reverse manual valve body.
also i did know everything that Squirell  posted about which way the reverse shift pattern is vs the regular shift pattern and also the shift kit.  but i do appreciate the response tho.
i was just curious about the shift kit with a reverse manual valve body but i guess you just answer it (454 jeep)
thanks for the repsonses guys.
