...sending unit
Started by DirtyChevy, July 25, 2008, 03:26:39 AM
DirtyChevy
well i put a self tapper and a ground wire to the frame on the sender right where it was from the factory...ran the positive up under the dash to the pink line black wire (or vise versa) and nothin happened...well then i relaized duh you need power....so i took out the test light and the other side of the pink black wire had power so i spliced it in and then the gauge just went to full and i know it's not full....so what should i do the tank is a blazer tank and it's gm obviously....what should i do to get it to work? thanks
FRIENDS: will talk p00 to the person who talks p00 about you.
REDNECKS: Will knock them the f#$% out
chevv ==rocks chevv     REAL men wear bowties
Brook Chadwell is MY baby
DirtyChevy
Bo Duke
Take the sending unit out of the tank and bend the rod on the float????
Bo Duke
No, but really the sending unit u used could be a dif ohm value, and would make the gauge read wrong, not sure tho.
DirtyChevy
Bo Duke
yeah i wasnt sure so... just tryin to help
