LS valves in small block
Started by 2000silverado, August 15, 2008, 03:22:22 AM
2000silverado
did you guys know about putting in LS valves(1999-current) in early small block heads. u just need 8mm inserts for the guides and the valves. the intake valve stems are hollow and the exhaust are sodium filled. lightweight and big valve size!!!! u can also use the lightweight beehive springs. some machining is required but it is a good suggestion for lightweight valvetrain!
