4x4 problem again.
Started by motersports3211, August 27, 2008, 08:06:46 PM
motersports3211
ok im stumped
its a 96 gmc jimmy
i hear the tcase switch over and i watch the front axle(differential) engage but its not working i go four wheeling and all that seems to be working is two wheel?!?
does any one have any ideas plaese let me know.
chevgal I'll Drive Anywhere As long as theres mud!! chevgal
Kodiak450r
easy way to find out the problem. put the truck in 4x4 leave it in park. jack 1 front tire up and spin it. look under the truck while spinning it. if the front drive shaft turns you have a t-case problem. if the d-shaft doesn't spin then your front axle is broken or not fully engaging.
Bo Duke
Quote from: Kodiak450r on August 27, 2008, 10:18:14 PM
Yeah could posibly have a broke chain, or a broke axle shaft....
its the front axle actuator! they go out alot..... use a posi lock they rock!
motersports3211
#4
Quote from: betterbeaters on August 28, 2008, 12:28:47 PM
i pulled the actuator out of where its held in(under the battery.. stupid spot for it.) but i left it all hooked up,put the truck in 4 wheel, and it pulled the cable as far it could be pulled so i dont think thats bad. but still no 4 wheel. plus i only wheeled with it like 2 times since its been new. but as soon as i scrap up enough cash im gunna buy the posi lock. ive been looking into them for a while.
the actuator should be on the front axle...... or at least it was on mine.. I would jack it up in 4x4 and spin a tire like they said to see what it does I bet you broke the front axle... good luck
2000silverado
i had a similar problem with my 94. i took it to transmission technologies and they told me i had blown one of the pressure seals in the t-case that connects to the tranny?! cost me 150 and it worked fine after that but to this day have no idea what they were talking about! never heard of that.
