chevy 302
Started by Squirell, September 06, 2008, 10:13:56 PM
Squirell
I need a little insight about this. i have a 327 and a 283 crank to do this just wondered how they run how well they take high rpm's. let me know what you know about these thanks
Swampthing
a 302 was a 3.00 stroke crank,with a 4.00 bore block..  it used 5.7 chevy rods..and the pistons cost a small fortune... it was ok..yes high rpms.but very low torgue. no real reason to build one, unless it was to put a car back to original..  in my own opinion..it is wayyyyyyyyyy to much to build.. for the power you will get. build the 327 instead..it is a 3.25 stroke, with a 4.00 bore block.it also uses the 5.7 rods.. pistons are reasonable.. and the power difference between the 302 and the 327 are amazing..
Squirell
jeep man
#3
squirell you need to put a real power motor in that jeep amcc  it wood run for ever  jkk good luck man  HR
jeeppgal jeepp   In life  if your not living on the edge your taking  up to much space.
