Front Superior Axle for '05 Jeep
Started by GM Jeeper, October 09, 2008, 11:06:36 AM
GM Jeeper
2005 Rubicon
Has anyone replaced their front axles with Superior Axles?
My question is, will I need to replace the inner axle tube seal too (bigger shaft?)?
The catalog says they come with a new seal (I'm still waiting for the parts to come in).
So I'm thinking this job ain't going to as easy as just swapping out the shaft assemblies.
If I need to replace the seal, how difficult is it?
*~* Affordable Magician for Hire*~*
"Daily driver......if I roll it, I'm screwed!"
"Some mistakes are too much fun to only make once"
[img width=133 height=100]
[img width=560 height=29]
just one more
the shafts should not be bigger just made out of better material.
if the shafts were bigger you would ned a new dif as well.
i put moser shafts in mine and the o.e. seals work fine.
