steering issue need help
Started by MOOSE13, November 01, 2008, 02:13:35 AM
MOOSE13
right now i have a 76 k-5 blazer with 18 in lift and 44's i have a ford d44 hd axle on it now with crossover steering looking to put a chevy d44 hd on it for different diff side but the steering knuckles are different and i dont know about just getting a drop pitman arm if it would be big enough and i kinda like the crossover set up and help would be appreciated
Get yourself a set of flat top knuckles for the 44. I just so happen to have a set, and the Steering arm. PM me and we can discuss a price.
Are you sure you can't use the ford knuckles on the chevy I'm pretty sure they are interchangeable I know most places that machine the knuckles for crossover don't like using ford knuckles due to a small flattop casting the recomend that you get one off a chevy or dodge. ??? ??? ???
and even if you end up using a chevy 10 bolt You should be fine I've got D44 HD knuckles  on my 10 bolt front.
MOOSE13
thanks for the info everything helps
