what do you heat with
Started by millser, December 04, 2008, 01:48:16 AM
millser
what do you heat with how worm do you like your house ,shop
Natural Gas & Wood when I have some
millser
wood ,lp back up our house stay around 80
Rollover Herb
CORN  HOUSE  SHOP  CORN  NAT GAS
==ogm
MudMonster
nat gas house and wood in the shop
WORK HARD MILLIONS ON WELFARE ARE DEPENDING ON YOU
natural gas for house and shop. house is at 68 shop is off for now waiting for concrete floors and then have to move everything out there then it will be at 50 when i'm not working in there and around 60 when i'm working out there.
blazentrout
propane for the house, wood for the shop
Ghetto Fab
nat gas in the hosue  salamander in the garage usually with kerosene loll   house is set at 65 all the time
SteveP612
House is heated with natural gas kept temp around 64. Yes I know that temp is low but at work we have to keep the control room around 60 to 65 to keep the computers cool. Shop is heated with Kerosene.  Looking for a wood stove for shop.
1997 Jeep Cherokee and 91 YJ
Wizzard
startin over...again
dossows
natural gas in housr  74 deg.
garage propane 60= deg.
Russ
wood in house and lp as a back up   keeps the house about 75-80
chetney
Squirell
nat gas in the house wood in the garage
mudpuppyracing
 Propane in the house. Set at 62'.   Propane and wood in the shop. 55' till i fire up the wood stove then it's 70',80',90'  etc. Hard to regulate the wood stove. :)
Stock Sucks!!!!!!!!!!!  Pete............. oops
MUDFINDER
House Natural Gas 60'
garage wood when out there
Middle Road Mud Slinger
boggnass10
LP in the house , wood in the shop once I install a chimney
95 S-10 468 BBC rear engine , dana 60 detroit locker, 14 bolt welded
456 gears, 203/205 doubler,400 turbo, 44 boggers,and 4 linked.
NG and Wood - house
Kerosene in the garage.
Huddled around a match! loll Right about 52 degrees.
jkeldsen
Wood and Geothermal. Geothermal hardly ever turns on
