Dana 60 ?'s
Started by RedneckMudder, January 25, 2009, 11:51:07 PM
RedneckMudder
any things i have to do to switch my D44 out for a D60? and can you run 15" wheels on a D60?
Truck-$1200
Lift, Tires, Axles-$1000
Misc. Nuts & Bolts-$650
28 Cases Of Beer-$280
you  can runn 15 " wheel on a D60  just  have to grind the  calipers.
if its  chevy to chevy,  you should be ok  other than a  ujoint   other than that ==dunno   need  nore  info  on   what it came out of  and  what its going in.
Is your D60 a Dodge or Chevy?  I think their is a spring perch width issue when using the Dodge axle in a Chevy, chevy is direct swap, My Corp 10 to a D60 was pretty much a direct swap, except for a few things...........Larger U bolts, different steering correction parts, brake calipers and hoses
15" rims will work on a D60 with ALOT of grinding!!!!!!  I had probably at least 2 hours a piece in grinding the calipers down, not fun at all! 16's or 16.5's are the better choice but I used what I had which was 15's.
My Ujoint in the front shaft was exactly the same as corp 10, Im sure their are other sizes out there though.
15 in wheels   with no more than a 2 in off set       if its a dually     grind the hell out of the calipers     maybe front u joint      and a ubolt top plate if you dont get them all   ream the 2 holes a little
If you have a dually setup, and don't want the extra width.. you can cut the hubs down.
