true or false ???
Started by mudslayer2008, February 10, 2009, 06:29:07 AM
mudslayer2008
I was told buy a guy I work with that the 400 turbo I have will shift from 1st to 2nd even if you drop the linkage manuly. He said it will shift on it's own to 2nd no matter what you do unless you change the valve body.  I myself have a hard time beleaving this because if you put it in 1st gear manuly it should stay in that gear until you change to the next gear correct ?
  Was wondering who runs or has run or has any opinions or facts about this transmission.
Norm Henderson
it will change at like 50 mph i think.....it wont shift like it normally would, but i belive it will shift
Drive It Like You Stole It
Jr
it will unless you put a manual valve body in it
Disturban
Mine dont...it will stay in first with your foot to the floor all day long. A 4l80e will though, computer says (HEY DUMB ASS LETS TRY SECOND) and it will shift ==roll
Norm Henderson
duh....sorry im a ford guy....i knew one of em did it
dossows
I've had 2 chevy vans 86 and 88 and both them would shift on there own from 1st to 2nd. And leave black marks, feels like a shift kit in it when it shifts on it's own
Russ
Squirell
they all should shift. if they are stock, however you can get transpaks for them that will make them not shift if you put them in first
All stock TH400's will "panic" shift from 1st to 2nd. The only way it won't is if the valve body has been changed or modified.
Gearz
 The trans has too come out of truck too change valve body  I suppose. Not a tranny guy  ==idk where  do you get manual valve body too put in. Too change that problem? :(
a trany shop should be able to get you the parts,  and  you should be able to leave in the truck to change.   take bottom pan off and its  above your  filter.   some  auto parts stores can get  them.
I ALSO THINK YOU CAN SHIFT IT BACK TO FIRST    WHEN IT DOGS BACK DOWN   THE OTHERS WONT TILL THEY HIT   CERTAIN SPEEDS
yes a 400th will shift at about 5000 rpms all the time you can change the valve body or rebuild the gov..
yep  it'll panic shift... my 4.3 sblazer does it dam near everyday... hate it loll then doesnt drop back into first for bout 10 seconds with my foot back off the pedal. Manual valve body would take care of that.. i dont think a shift kit would... maybe?
SteveP612
Quote from: Gearz on February 10, 2009, 12:57:49 PM
Gearz you can by them through Summit or Jegs you can also get them to change the order of the way they shift.  Reverse Valve Body.  Which means that the first forward gear would be 1st instead of drive.  Dont know how hard they are to put in.  I had a Jeep that already had the reverse valve body in it.
1997 Jeep Cherokee and 91 YJ
i think you can change valve body with trans in the truck... not sure tho.. i was told i could put a shift kit in with trans up in the truck. ???
Stump Jumper
valve body is just inside the pan can be done in the vehicle. sucks on your back though.
Gearz
my th400 does it too changing everything though before i put it in next truck loll
Wild One
I run 400 turbo with a manual body.
I love it, what gear I want, is what gear I have.
Just remember, you put it in 3rd (drive) at take off,  you are in that gear.
Disturban
I dont have a manual valve body and I swear to god on my grand mothers grave it will hold first all day long...it also has a real strong shift will chirp the tires from first to second. Must have a shift kit but would a shift kit hold first gear like that? I know my trans was rebuilt about 50k ago and the guy used my burban for towing he also had a big ass tranny cooler installed, my fluid is nice and pink and smells brand new. So I was just wondering if there was shift kits designed for towing that would allow you to hold first? Maybe that would explain mine? Or could something be wrong with my trans?
