Quik lock or lock right lockers
Started by wildbroncoII, February 11, 2009, 01:24:22 AM
wildbroncoII
i run a quik lock locker in my hp dana 44 and last year the pins broke so i replaced them now where the pins sit is complete broke wondering if anybody else has had this problem? also thinking or changing to a mini spool in front truck is only used in mud any pros or cons to this?
91 k1500
without at least hydro assist I think you will have a real hard time turning when the hubs are locked in with a spool
locker in front ,  spool or  weld the rear.   just my  ==2cents
I run welded spiders in teh front and truning the wheel is not bad with stock sterring but you will have to make 20 point turns but it works sweet!! and yes I would put a spool in the front
Quote from: 91 k1500 on February 12, 2009, 11:22:56 AM
Unlock one hub.
91 k1500
Quote from: Disturban on February 13, 2009, 04:26:20 AM
Unlock one hub.
why bother putting a spool in it then?
#6
Quote from: 91 k1500 on February 13, 2009, 05:33:09 PM
Unlock one hub.
Unlock one hub when you need to make a tight turn...then get out and lock it back in.
If it is strictly a mud truck how many tight turns do you need to make. Now a trail rig would be a different where you make alot of tight turns.
