have you ever installed a 5" trailmaster ifs lift kit on a s-10 blazer w/4.3L
Started by Jr, February 16, 2009, 06:30:55 AM
Jr
ok im reading the instructions online and it says the exhause has to be modded for some ungodly reason! i was just wonderinf if anyone on here has done one of these and what has to be done with the exhaust. ide appreciate your help
by the way i havnt bought one yet im just shoppin fer good prices!
play time
I have been looking at lifts also, and it seems like there are quite a few problems with the TM lift.  Seems like most people that bought it wish that they would have gone with the 6" superlift kit instead.
That said, I also would like to know why the exhaust has to be modified???
1982 Olds Cutlass
It has to be modified so the front driveshaft doesn't hit it, in stock form the driveshaft is above the exhaust, then you drop the front pig and the exhaust makes it so you can't hook the driveshaft back up HTH
Jr
Quote from: jr on February 18, 2009, 12:03:14 AM
soo run duals then...hells yeah
that works put the lift on then have the pipes ran and you'll be fine ;) ==roxx
