Best Locker For The Corp. 14 Bolt FF
Started by TBigLug, February 19, 2009, 01:41:30 AM
Other than a stick weld locker, what is the best locker in terms of reliability, longevity, cost and ease of installation?
What do you guys run?
detroit locker. my dad puts them in 1000hp cars with dana 60s and the dont break. i figure they are just as strong for a 14bolt
just one more
do you drive on the street? if not go with a spool, ALOT cheaper
No doubt... a Detroit.
Have one in my Suburban and also my Blazer.
Quote from: moparmudman on February 19, 2009, 03:42:02 PM
Good point.  But, even when driving other than the street... have the ability to unlock at times is a plus.  But, if cost was that big of a factor, a spool is a great choice.
DETROIT LOCKER!!! SWEET ON AND OFF ROAD!!! GOT ONE IN MY BOGGERS REAR END AND LOVE IT!
detroit hands down...the winner,
just make sure the 14 bolt you have, is OPEN........meaning it has no limited slip or Gov lock.
Because a detroit locker will only fit in an open carrier.
just one more
detroits are awesome dont get me wrong, i have them f & r in my bogger.
all i'm saying is that spools are super cheap, if you only plan on bogging
you could save $400, considering mine were roughly $525 each not to mention
the install kits.
This truck spends 75% of it's time as a DD. I had thought about a spool. With the killer deal I got on my tires I can afford to have them wear out a little faster. I just don't want it to have too bad of manners on the street for when Heather drives it.
Now, what's your thoughts on buying a used locker? I saw one on Craigslist for $200.
Quote from: TBigLug on February 20, 2009, 12:05:45 PM
then you dont want a spool.  Spend the extra couple bucks and get the Detroit.
My old dd Suburban with a Detroit in the 14 and 33s was totally fine on the street.  Would only chirp when I got on it going around a turn.
Now, myCJ7 with a welded rear end was horrible on the street.  It would push the front when you turned and turning radius was almost doubled.  And tire wear will be excessive.
Quote from: TBigLug on February 20, 2009, 12:06:39 PM
Just check it over good.  Detroits are pretty damn durable.
