straight axle conversion
Started by Groundhawger, February 25, 2009, 05:23:14 PM
Groundhawger
IM PLANNING ON DOING A STRAIGHT AXLE CONVERSION ON MY 98 Z71. I HAVE NO IDEA HOW TO DO THE FRONT END SET UP FOR SPRINGS. BUT IF I USE A TRANSFERCASE FROM AN OLDER CHEVY, LIKE AN 85 CHEVY, AND USE A GM FRONT SO DRIVESHAFTS WILL BE ON THE PASSENGER SIDE, WILL THAT WORK?
chevystudz7105
yes that will work.  that is how i was going to do it to my 91 when it was in the plans of doing a sas.  but here is a website where you can order all the mounting brackets and all that is needed to make this possible.    http://www.sky-manufacturing.com/new/
one good thing about the crossmember you get from them is when you bolt/weld it in  you get 6inchs of lift with a stock set of front leaf springs vs the 4 inchs you would get with just using the mount brackets off a parts truck if u did that.  only down fall is the price of it.   but that was the way i was going to go when i was going to do it.
73chevytruck
you could just use a solid ford front axle, the pumpkin would be on the drivers side and you wouldnt have to get another transfer case,
pm wildtime  hes done it before and can make your brackets
solid 12
yep, that is exactly what i did to my 98, i love it!! just keep in mind that the rear springs are very expensive! i paid $725 for some 5 1/2" lift springs and used a 3" block
redchevy11
http://www.sky-manufacturing.com/new/detaproduct.php?id=64
get this and use a ford dana 44 or dana 60 front axle...then you don't have to change your tcase...
I would get a matching set of 3/4 ton axles....You will need leaf springs for a 73-87 chevy for this kit. and some shocks...relocate shock mounts in the front.
and more parts depending on how much lift you want.
