does anyone use limit straps/chains?
Started by ROCK, February 28, 2009, 10:22:53 PM
ROCK
seeing if anybody uses them on there truck. where did you mount yours and wnich do you prefer?
i'd use straps, they'll stretch a little bit
mount it right in line with the axle ==np
Matt
just wondering why you would need them? if you dont have them could it do damage to a leaf spring suspension like slymers, by what over extending on one side? (just trying to gain some knowledge)
97 Chevy  2'' body lift, 79 cj7 31 tsl's
Matt
#4
over extending the shock
[/quote]
gotcha   so the leaf springs dont do the job huh?    im going to guess thats only when your vehicle can do some major flexxin
They will also help with slip yolks..
drive shaft slip yolks can seperate if over extended..
on a transfer case.. a slip yolk will slide off of the end of your output shaft..
Bo Duke
Or in the case with my truck the coil springs could pop out of the pockets.... and cause a really bad day...
Norm Henderson
Quote from: mac_henderson2001 on March 02, 2009, 06:12:42 PM
that wont happen mac you have that lil bitty piece of metal holding em in loll
Drive It Like You Stole It
