Has anyone ever heard of pouring water into the engine to clean it?
Started by mathew21, March 03, 2009, 09:50:11 PM
bigdawg41
one thing to remember is that water does not compress like gas and if you give it to big of a "drink" you could bend a rod!
creepyjon
this is a very old school trick, and that's NOT the right way to do it.
Use a small spray bottle filled with water, and put a fine mist of water into the engine. Never put liquid water in an engine in large amounts, it will cause hydro lock and blow a piston. You can also do the same thing with any flameable cleaner, like carb clean and it will clean out the carbon as well.
ive done it... not sure if it worked or not... motor still ran fine.. it smoked like crazy when i was puttin the water down the hole... so must have done something... water dont burn.. smoke had to be comin from somewhere and it wasnt blue.
basic idea behind it as i was told is the valves and etc. get hot then u dump cold water down there and it shocks the metal/carbon.. makes the carbon crack away from the valve and get burned in the combustion chamber.
like said above... if ya dump too much down at one time you run a risk of hydro locking the motor.
MudMonster
WORK HARD MILLIONS ON WELFARE ARE DEPENDING ON YOU
CBakes
Thanks guys....just did this and locked up my motor!  J/K WAY TOO CRAZY!! Never heard that before.
biggator64
i use water all the time in carbs it works great i use a 20 oz bottle worth.carb cleaner smells and is bad for your lungs
mudbrat71
done alot like 100 times  but 1 time had big chunk of carbone fall off got stuck in valve and bent it that sucked  but works 99 percent of time
