installing new rings in a bbf
Started by mudslayer2008, March 12, 2009, 03:12:03 AM
mudslayer2008
I need to put a new set of rings in a 460 ford I was wondering if I can order the standard bore or if I need to order oversized
rings because I am going to hone the cylinders. right now there is no rod knocks but smokes really bad (oil) and there is gas in
the oil (blow by) but it has minimum compession I can turn the engine over with the fan belt using my hands.
The ring kit I'm ordering comes with ring,rod bearings, main bearings, and all seals and gaskets for 183.00 + tax
Norm Henderson
youll be fine with the standard ones
Drive It Like You Stole It
mudslayer2008
thanx I'm ordering them on friday it'll  take a week to get them
mudbrat71
clean tops of pistons make sure someone has not had apart and bored it already  if so should be stamped in top of piston what size
check you pistions   like  said above.   what if your  crank hase been turned ,  it  mite  be  .10  .20    or  .20  .20   you  mite  have to take it apart to  find out.
how  do you  know  everything is  standard ?
mudslayer2008
just going by what I was told the motor was when I got the bronco
mudslayer2008
I'm going to try and get to motor out today/night and get it torn down so I can see what it all looks like thax for the advise thats y I like this site.    people always willing to help
invest in a digital caliper...
no second guessing if its been bored or crank has been turned... look in the manual for specifications...
mudslayer2008
I guess I'll have to get a manual I don't have one for any ford let alone a 460 bb
thatll give you all the bearing clearences and torque specs as well ==np
mudslayer2008
mudslayer2008
does    n  e  one know if I need to get new head bolts for this 460 ???  I know on small blocks the head bolt stretch and need to be replaced,  but not sure about the big blocks.
