HELP!!!!
Started by camok10, March 26, 2009, 03:14:41 PM
camok10
ok i broke the themostat bolt off on my 89 k5 w/350 and i heated it up and tryed easy outing it and that didnt work. so i tryed drilling it to tap it for a new bolt and the drill bit broke. so if the bit extractor dosent work to get the bit out today what should i try next ??????
84 c10 project
82 c10 beater diesel
just one more
hammer and a punch or solid carbide drillbit, possibly a left handed bit?
but if you break off the carbide you are fubar, after that E.D.M. is only choice
try welding a nut to the end of the bolt, that will do 2 things 1. heat the bolt and loosen corosion, 2. give you a way to run the bolt. you just gotta get good penitration into the bolt. ==2cents
camok10
therers not enough left for the welding a bolt, i allredy thought about that.  and we had it glowing with the torches too befor the drill bit broke.
i may try and find a carbide one to drill it out with
also we tryed air hammering the part that was still above the manifold and it didnt even budge
and thanks for your 2 cents guys
84 c10 project
mudslayer2008
I've got a stock sbc 4 barrel intake if you need it.
Quote from: mudslayer2008 on March 26, 2009, 05:31:25 PM
That might be your best option if the carbide doesn't work.
camok10
it is tbi and the intake is actually cast iron
but good news i got the bit out and it is awating me to tap it tommorow in day light
84 c10 project
mudslayer2008
glad you was able to get it fixed
camok10
84 c10 project
biggator64
did you get it fixed if not i have a intake
camok10
got er fixerd good were are you at in dansville ???
84 c10 project
biggator64
lilhoss
i was gonna say torch it and get a new in take
camok10
Quote from: biggator64 on April 03, 2009, 09:54:59 AM
south of town
im by m36 and merdian
Quote from: lilhoss on April 03, 2009, 01:14:47 PM
no offense but horrble idea and why wast time torching it if im just going to get a new one anyway  ???
and thanks everybody for your input
84 c10 project
