small block vs. big block?????
Started by jays85, March 27, 2009, 01:11:13 PM
jays85
i just got my small block in my street rod done (turns some ponys) it is not something fancy but i biult it the first motor i have built now i have a buddy that has a 402 big block he wants to trade running motor for running motor  would you do it??????
middleroadBOB
for sure, nothing beats the torque of a big block.. i will never go back to a small block
whats you motor? and what his? specs?  big blocks can make more power but the small block is lighter and cheaper.... I run a 600 hp 383 and love it! but if I had the cash I would build a big block 540!
jays85
#3
mine is a 350 targetmaster crate .40 over cast iron heads (i dont know much about) proformer intake 650 edelbrock carb. 50,000 volt  distb. flowtech headers it dont seam like much but it a 86 chevy 2wd and hit it your all over the road
his a 402 with roller rockers i think he said sometihng about a 275 cam i beleive stock on everything else, even manifolds !!!
the harvester
TOMAC
Quote from: tits and beer on March 27, 2009, 02:46:56 PM
go big block
races are won by displacement....  if you think that aint true your not american
Swampthing
how many miles are on the big block? what did it come out of? have you heard it run? what comes with it?  does it have all the pulleys and power steering brackets?  after market  intake and carb?? There is more to putting a big block in where a small block was, than just putting it there..  Remember. when ever someone wants to do a trade that is "almost to good to be true" it usually is.   And remember. stock big block chevys DO NOT LIKE RPM.  anything over 6000 will hurt it.
ufospy
   FOUND ON ROADSIDE DEAD___ROAD KILL!!!!
tntmud
#10
Quote from: TOMAC on March 27, 2009, 03:07:49 PM
go big block
Hmmmmmmmmm     never seen a big block in NASCAR     jkn    loll
Small block is cheap reliable HP     Big blocks are NICE but expensive     Nothing like hearing a small block twist 9000rpm ( but not cheap either )
Show me the MUD!!!
SteveP612
BB are nice but your already set up for the SB.  Keep it unless you can get everything that needs to be changed over to the BB
1997 Jeep Cherokee and 91 YJ
Quote from: SteveP612 on March 27, 2009, 07:18:17 PM
Ditto...plus you know exactly whats in your motor and how many miles are on it. His might have a gazillion miles and be ready for a rebuild. I would take a built small block over a stock big block any day. No replacement for displacement is true to a certain extent...I have killed some big blocks last summer with my Trans Am 425hp with a 150 shot. Whomped on a 396 chevelle and also a 440 road runner like they had a 6cyl! Keep what ya got and if you want big power save up and build a big block the right way...but be prepared to spend big bucks!
Wild One
I run a Big Block.
I love it.
But.................
built 350  or stock 402 ????
52 cubes difference is not enough for me.
I would stay with 350
mudslayer2008
Quote from: Wild One on March 28, 2009, 12:44:52 AM
I run a Big Block.
I love it.
X2  Keep what you have at least you know what you got
Boggen Joe
Theres a reason he wants to trade, unless its in great shape n low miles. keep your sbc
millser
i will trade a 40 over 350 for it if you dont want it let me in on this deal LOL
ROCK
There is very little that will have to be changed over.  Motor mounts are the same.  Trans should be the same.  MAYBE radiator, but I highly doubt that in this case.  Pretty sure all the accessories will work.
You going to trade ignition also?
big white chevy
i would stay with the sb in a street car
