Chevy 10bolt U-joints?
Started by Disturban, March 28, 2009, 04:12:11 PM
Anyone know who sells spicer u joints locally for a front chevy 10 bolt? Also does anyone know what the part number is? Does Napa sell spicer?
Last I heard, spicer went out of buisness. Might find a few floating around, dunno ???
Quote from: homewrecker john on March 28, 2009, 04:16:12 PM
No...they are still in business. If I cant get spicers locally anyone know of a u joint that is comparable in strength? I called napa and they cant get them for my truck? But they have some life time u joints made in the USA for $35 a piece.
suburban auto has them i think
RedneckMudder
Quote from: J.C. on March 28, 2009, 05:40:26 PM
i think your right, they have alot stuff there and i think ive got one there b4
Truck-$1200
Lift, Tires, Axles-$1000
Misc. Nuts & Bolts-$650
28 Cases Of Beer-$280
go talk to someone at auto value, whoevers been there the longest.. they can prolly hook ya up.
if ya cant find the spicers you want, precision makes some good ones too... they make a heavier duty one for axle joints too
yeap.. thats what i got ... precision u joints are lifetime warenty too.
#8
Quote from: Eroq on March 29, 2009, 04:38:33 AM
Thats what I am looking for is the axle u joints...who sells the precision? I was looking at OX (BAD MO FO's) But they are like $180 a piece...screw that!
umm.. AutoValue ;D haha, you prolly need (part number) PRE 317 but double check with them, u could need a PRE 353 those are the 2 most popluar, and the 534 but i think thats ford. I like them because the grease fiting is in the end of the cap, alot easyer to maintain. Plus lifetime warenty w/ recipt
Those your looking at about 14-15 buxs a piece.
chevystudz7105
not sure how far away you are from bay city, but joint clutch and gear sells spicer joints.  the part number that you need for the axle shaft u joints is 5-760x.  i just picked up 2 for my truck yesterday.
Quote from: chevystudz7105 on March 29, 2009, 07:49:45 PM
To far from Bay City however thank you for the part# I found them on Ebay.
i have a box from one i got, i'll check for part # tomorrow
bigdawg41
got my spicers from southwest brake in mt. pleasant
Is this for the Blazer in your avatar?
If so... go with the lifetime ones from wherever.
If its a daily driver, get the ones with the grease fittings.  If not a daily driver get the ones with out the grease fitting as they are stronger.
I used to use the cheapy life time ones on my CJ7 with 35 Boggers and a big block.  Worked just fine.  Broke a couple... but the axle shaft went and took out the joint.
My store of choice at the time was AutoZone.
No, if this is for soemthing with a lot of power and larger tires... pay the money and get the best you are willing to spend the money on.
CBakes
Clydes Frame and Wheel just put Spicer U-joints in my newly lengthened drive shaft for my Blazer. April 1st actually. They are in Pontiac Michigan.
Squirell
OakleyOutlaw
I used Brute Force joints in my 10 bolt never broke any get them at any Auto value store
I just got the precision's...I have heard a lot of god things about them. They are made by Federal-Mogul.
yea.. i found the right part number i think... they was PRE-534G for chevvv
