need help quick
Started by Groundhawger, March 31, 2009, 09:05:58 PM
Groundhawger
WE JUST PUT NEW HEAD GASKETS ON A 93 CHEVY WITH A TBI 350. WHEN IT IS COLD IT RUNS BAD, IT WILL REV UP, THEN BARELY IDLE, IT WILL KEEP DOING THAT AND IT WONT IDLE NORMAL. WHEN IT GETS WARM, IT RUNS GOOD. ANY IDEA'S? ALL NEW GASKETS AND WE CHECKED FOR AN INTAKE LEAK OR TBI LEAK AND EVERYTHING IS FINE. ANY IDEAS'S? GOTTA GET THIS OUT OF THE GARAGE TONIGHT SO ALL HELP IS APPRECIATED, THANKS
#1
Either ya got a leak somewhere (Intake gasket) or you might be off a tooth when ya put the distributor back in. You also might have missed a vacuum line and are sucking air.
Did not see it runs good when warm? Mmmmm I think Cornbread just went through this same problem...I forgot what it was though. Might want to PM him.
onetoughchevy
 did that year com with an iac sensor that will do something similer to what ur discribing
Groundhawger
now when we have it running, when we turn the headlights on or hit the brakes it dies.
mudbrat71
Quote from: mudbrat71 on March 31, 2009, 10:06:23 PM
ground
there should be a ground on the back of the passenger side head check that ==shrug
Quote from: Mudbuster on March 31, 2009, 10:20:29 PM
ground
x3   ground wire
Groundhawger
all grounds are good. engine still running bad on idle. not sure what is going on
Grounds, IAC (idle air control valve) or CSV (cold start valve). My three suggestions.
mudbrat71
relash your valves if to tite u will not have enough vacum to run rite and computer will try and compinsate for it
Groundhawger
Quote from: TBigLug on April 01, 2009, 12:17:30 AM
were are these located?
Mudduck
Mudduck
==hstrap
mudbrat71
Quote from: Groundhawger on April 01, 2009, 02:35:14 PM
iac on throtle body 4 wire sqaure plug  u should have 3 ground wires at thermostat housing and 1or 2 at back of heads and no csv
