WEIRD NOISE??
Started by KORNBREAD, April 05, 2009, 02:44:19 PM
87 CHEVY K5 10 BOLT,6 LUG FRONT AND REAR,ALL STOCK! (ITS THE ONE IN MY PROJECTS PAGE).. ANYWAYS NOW THAT ITS GETTING CLOSER TO BEING ROAD WORTHY ME AND SWAMPRAT TOOK IT OUT YESTERDAY WHEN WE WENT FISHING. I NOTICED THAT WHEN I WOULD TURN AND THEN STRAIGHTEN IT BACK OUT TO GO I KEPT HEARING WHAT SOUNDS KINDA LIKE A FRONT WHEEL DRIVE CAR SOUNDS LIKE WHEN THERE CV AXLE IS GOING OUT.(YOU KNOW THAT CLICKING SOUND IT MAKES). WELL ITS NOT REALLY LOUD BUT YOU CAN HEAR IT. SO WHEN WE HIT A EMPTY PARKING LOT I TURNED THE WHEEL ALL THE WAY (LEFT AND RIGHT) AND WHEN YOU GIVE IT GAS AND START MOVING YOU HEAR LIKE THIS CLICKING, BINDING SOUND UP FRONT. (WELL ATLEAST IT SOUNDS LIKE ITS COMMING ROM UP FRONT). WE WERE THINKING WHEEL BEARING MAYBE, BUT IM NOT SURE ON THAT ONE. PLEASE HELP ME. ALSO EVERYTHING UP FRONT IS TIGHT AND DOSNT MOVE WHEN I PULL ON IT SO IM STUMPED!
is it a full time  t case,       do you  have  lock out on the  axle.   or is this a  full time  system ==dunno.
its a 261 (or 267 dont remember) case, lock out front. sorry forgot to mention that. lol
AND THE LOCKS IN BOTH IN FREE     NOT TURNING THE SHAFT    AND THE WHEELS NOT HITING ANY FENDER  PLACTIC   ARE YOU ON OR OFF THE BRAKES     DID A BRAKE PAD DROP     YOU ONLY GOT 2 BEARINGS      AND A SPINDLE BEARING   AND U JOINT        GOOD LUCK
i had an 85 that did this. check to make sure the u-joint caps are all there. on mine i was missing 3 and it would click like that
both lock outs are in the free position. no tire rub. all the caps are there.
SteveP612
I had a 98 Tahoe that when you backed it up I would here the same thing.  It took us a while to figure out that it was a U-Joint on the rear drive shaft.   It actually wore on the cap funny to the point that it elongated the inside of the cap and had almost no bearings where it would make that noise.    You need to look at all the caps to see if there is possibly a gap where the journal goes into the cap.  It almost wore a hole into the side of the cap.  Hope this helps
1997 Jeep Cherokee and 91 YJ
ok ill check the rear caps.
CBakes
#8
I've experienced that noise from time to time with a couple different 4X4 trucks. In all of the trucks at one point it came down to replacing the axle joints. When turning, the axle joints would bind up when they are really worn out. They were so worn out in my 2001 Ram Off Road that they began to click going straight! It's like a crunching click noise right? I would definitely check them out. It's a  p00 job taking the entire front end apart to replace them...and watch the axle seals when you put them back in! You can easily damage a seal and they will begin to leak out. That's what I think it is. You might be able to get a pry bar on the joints and do some wiggling to see if there is any slop in them.  Good luck.
ya i took my pry bar and the u-joints in the axle are solid. there very strong and have no slop. im still stumped so im gonna lift the front of the truck up and start slowly tearing both sides down and go threw every part till i find whats wrong. i do know the front drive shaft u-joints are shot but  not the problem cause when im in 2wd the front drive shaft dosnt move.
check n see make sure ur steering box isnt loose.. jack up the front end and start shakin stuff.. somethings gotta be loose..    my dodge was doing that, but that was cuz the auto lockouts were tryin to engage, and i had a bad upper ball joint.
