Help 400 trans questions.
Started by Bige4457, April 17, 2009, 02:59:38 AM
Bige4457
Well  got the 425 cadillac motor out of jeep went to drop the SBC in......oops I Forgot that the BOP trans dont fit chevy LMAO.
So my next step I was going to get a 350 trans, but of course 400's and 350 have different tail shaft so Im not sure if a 350 will fit my adapter to the dana 300 tcase.
So basically my question is will a 400 turbo fit this adapter? any help will be appreciated.
Working for a living............
#1
Just buy an adapter plate that will allow you to bolt a chevy motor to a bop tranny...problem solved.
I've got 2 chevy 400's I'd sell for cheep just swap your gut's into one of them and your good to go ==shrug
I could even do that for you if you wanted.
Bige4457
was hoping if it would fit i would just swap in a 400 turbo and take the BOP out.........
If i hade a 350th and a 208 i might swap LMAO
Swampthing
a dana 300 is just strong as a 205 chevy case...why fix whats not broke,,,all you have to do is have your output shaft changed into a 400.. plus a kit to rebuild the 400 is only 120-130 dollars..  now add the cost of a 350 with a 208 and the different driveshafts.. the 400 looks cheap. and easier.. and no your adapter will not fit a 350.. the 350's have 4 bolts on the rear housing.. 400's have 6 bolts
Rollover Herb
GET A HOLD  OF  MUDMAN  SWITCH CASES  DOES ALL MY TRANS ON ALL MY VEHICLES.  DOES EXCELLENT WORK
==ogm
Bige4457
yea i figured the  swap of the 350 and 208 would be a pain....like i said i would rather just put in a 400. Do i have to change the output or will a chevy 400 bolt right up to that adapter to the 300?
cause if i can find a good 400 ill do that......but if i need one rebuilt then will definatley have to start talking to someone LMAO thanks everyone with the help so far.
Swampthing
you will have probably to get get the output shaft changed.
