air line humor
Started by bubba, September 21, 2009, 06:55:34 PM
bubba
Subject: Airline Humor
After every flight, Quantas pilots fill out a form, called a ?gripe sheet?, which tells mechanics about problems with the aircraft.  The mechanics correct the problems, document their repairs on the form and the pilots review the gripe sheets before the next flight.  Never let it be said that ground crews lack a sense of humor.  Here are some maintenance complaints submitted by Quantas? pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers.  By the way, Quantas is the only major airline that has never, ever, had an accident.
P:  Left inside main tire almost needs replacement.
S:  Almost replaced left inside main tire.
P:  Test flight OK, except auto-land very rough.
S:  Auto-land not installed on this aircraft.
P:  Something loose in cockpit.
S:  Something tightened in cockpit.
P:  Dead bugs on windshield.
S:  Live bugs on back-order.
P:  Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S:  Cannot reproduce problem on ground.
P:   Evidence of leak on right main landing gear.
S:   Evidence removed.
P:  DME volume unbelievably loud.
S:  DME volume set to a more believable level.
P:  Friction locks cause throttle levers to stick.
S:  That?s what friction locks are for.
P:  IFF inoperative in OFF mode.
S:  IFF always inoperative in OFF mode.
P:  Suspected crack in windshield.
S:  Suspect you?re right.
P:  Number 3 engine missing.
S:  Engine found on right wing after brief search.
P:  Aircraft handles funny.
S:  Aircraft warned to straighten up, fly right, and be serious.
P:  Target radar hums.
S:  Reprogrammed target radar with lyrics.
P:  Mouse in cockpit.
S:  Cat installed.
P:  Noise coming from under instrument panel.  Sounds like a midget poinding on something with a hammer.
S:  Took hammer away from midget.
vehicle #1 92 gmc jimmy 350/350 205 3/4 tons 4:10,s 38 swampers
Bo Duke
Dam Midgets in the instrment panel!!!!!  LOL
73chevytruck
larry60
Norm Henderson
==roll took hammer away from midget loll
Drive It Like You Stole It
I've got that same midget in my truck!
4xjeepfreak
motersports3211
chevgal I'll Drive Anywhere As long as theres mud!! chevgal
big red
live bugs on back order... iff always inopperative in off mode....
gator82
