Mow Money MowerSports "A Cut Above The Rest"
Started by Boggerram87, October 15, 2009, 04:23:36 PM
middleroadBOB
Boggerram87
Shes almost ready, just waiting on the rear driveshaft, and I gotta make one for the front, get some shocks and she will be ready for T-Day! Got her on 32" rollers for now
STEUERDUKES
Lookin good! Gotta love those K5s!
DRIVE FAST & TAKE CHANCES!
kEEP THE RUBBER SIDE DOWN!
rdtopkick
                               look nice
Gearz
Did you take a die grinder too your front shaft an cleaned the points were it would hit. Are you running a double velocity in your front shaft. Truck look's Bad A** . Love the plate. I got  MUD TOY for my plate on truck LOL Personal plate just a nice added touch.
Boggerram87
I was talkin to BogginJoe when I went over to buy some stuff off him and we got to talking about driveshafts and he told me that if you unbolt the front shaft from the diff and it can swing under the yolk that it would have enough flex, so I figured to see how bad mine is I went home and bolted it up to the t-case, and believe it or not it has enough flex on the shaft that I already had, only thing is it is about 3" to short, To be safe though im still gonna do some grinding. My rear shaft was at a bad angle to so I called up Tom Woods Custom Diveshafts and there sending me one, it got the double joint on it too
Gearz
Ya a little grinding now will pay off in the long run. I know I had too grind every spot that would touch an you would not believe the difference it made in clearance from shaft binding at weird angles.
THAT MUDFIT GUY
lookin good cant wait to see it at tday
Boggerram87
Well had to rip the rear axle out to fix the leaf springs, they were bowed in, I i figured I would eliminate the 8 degree shim i put in and beef it up a bit so I did some work to the perchs I got and the blocks and re-angled everything. Ordered my new Eaton rims with enough back spacing to clear the dana 60 calipers, and got the Boggers mounted up. Picked up a extra set off Millser so I cut the lugs off and mounted em on the extra rims to run on the back! All I gotta do is bleed the brakes and power steering tonight and she will be ready for T-Day!! yeahh
Gearz
Looking realy good. l like how you redid your lift block spring pad.
Boggerram87
Got Her Done! Lil left to do, shocks and front driveshaft but shes streetable, Great time at T-day!
Mudboggincrazy's Old Lady
looks like u had a blast at tday.. seen u out there
like those older Blazer's!
THAT MUDFIT GUY
I missed seein you at tday prolly cuz i didnt move to much  broke but i like that blazer
frdboy86
Quote from: Gearz on November 26, 2009, 04:33:45 PM
wattownbrown
#38
chevy boyz know how to do it right  chevgal chevgal
ballistics-10
All you need now is some 2.5 ton rocks and some tractor tires...
