Leaf springs or Coil springs??
Started by coolguy7, October 19, 2009, 02:36:56 AM
Pro or Con to switch over from leaf  to coil springs?
pro
Con
neither
coolguy7
I need some info about coil spring since my truck aready have leaft spring and heard that coil is best set up compare to leaf spring. What can ya tell me about it? Any experence? Degree of diffical? Any have blue print for coil spring set up? Who do this conversation set up? I need "pros" and cons" on both.
millser
not yet but i am soon taking 22 inch springs out and going with coil overs they say its $$$$$$$$$
coolguy7
Yes I agree but only if u r paying someone! If ya do it urself then u r saving tons of money and it pay itself over and over I think. don't ya think so millser?
coolguy7
i think it depends on what you plan on doing with the truck, if you plan on flexing it out i would go with coil springs or coil overs, also depends on if your trying to lift your truck? and how much, its deff easier to throw diff leaf springs in the stock place, but a good 4 link is what i would run if you wanna stand out from the crowd, with a nice set of coil overs , or  air shocks, and have a great suspension setup.4 link is way stronger too..Monster trucks dont have leaf springs for a reason!!!!
hrspwrjunkie355
agree with mi redneck u can build 4 link from scrath for farely cheap coil springs out of a ford pick up work good and some cutting measuring but u can also spend thousands doing it. but there is ways about making leaf springs flex to.
NO LITTLE BLUE BOTTLE
              ALL BALLS AND THROTTLE
coolguy7
i still dont have enough info here still need more input or guide into coil springs set up conversation from a leave springs
85mudbogger
You can never research this enough, it's all based on opinion and what your doing with your rig. Personally for a front suspension you can do a radius arm, a 3 link, a one link, 4 link, and in the rear you can stay leafs for stability or coil it 4 link, I like and run a 3 link front with xj coils and xj leafs in the back of my samurai but I'm soon going coils in the rear and I'm strickly offroad so I'm going with softer 150 # springs but if I was on road some maybe 200 to 250 for stability.
blazentrout
1. what is the truck going to be used for?
2. how much $$ do you want to spend?
3. what is your fab experience?
I have seen leafs ride better than coils and vice versa. Take a look at my jeep build, i built that supention for less than $300 but it was a lot of parts scronging. I can give you a very detailed idea on how to do this swap BUT i need some more info (vatozone time)
Make of truck
tire size
axle type
wheel base desired
stock frame or custom
ride quality
amount of travel desired.
This info should get me started on what you need as evrey thing is a dependes deal. Trout
Norm Henderson
Drive It Like You Stole It
coolguy7
Sorry I haven't come back here in awhile. So for Trout I will answer to ya hopefully I can get some info or perhaps some help.
1. Mud truck of course! Gonna want to jump also!
2. I'm in the poor house!
3. None! Did basic training in MCC that it.
1992 Chevy crewcab 2x4
Don't have tire but eyes balling 44"- 54" tires
Have HD Dana 60 front/HD Dana 70 rear Axles
Wheel base will gotta fit 54" between them crewcab with enough room for tire to flex without hitting cab
I have stock 2x4 frame can use this which is cheapest for me
Like ride quality gona be nice wih coil but what do I know! LOL!
As much wheel travel as I can get! More the merry!
Hope this gonna help Trout and hope this gonna get me going asap!
BTW gonna use what I have in stock is 454/700r4 or gonna get 4L80/doubler NP203/205 I have them all but tranny at the moment, Im sure im missing something else but hoping that some one gonna help me to get this going ASAP! This is poor boy mudtruck!
I have crewcab for tow rig with 30' flat trailer to haul above state mud truck!
